How to show module and SFP information include hardware serial number on Nexus switch?
freegreenworld
   How to show module and SFP information include hardware serial number on Nexus switch?                 Thanks.
Steve Fuller
Level 9
Level 9
The show inventory command will give you details of the Nexus chassis, power supplies, Supervisor, Fabric, I/O modules (including FEX if you have them) etc. To get the details of the installed SFP/SFP+ then you'll need to use the show interface transceiver command.
Thank you. Your Information helped me.
This discussion has been reposted from Data Center & Virtualization to the LAN, Switching and Routing community.
Vishnu_RR
I used QSFP CVR modules  to convert into 10G. when i input **show inventory all** i can only see the SFP 10G but i do not see CVR modules.
Is there any specific command to check the serial number of QSFP CVR modules. Please share.
