how to solve estination host unreachable?
Hi, I'm a student. I had a task making WLAN network. And I had to ping every PC. Ping goes to neighboring PC, but if you ping to other PC, it says "Destination host unreachable". Please help me to solve this problem.
The crystal ball says something is wrong in your setup. And if you share a diagram of your setup and the config, there might be help available.
sorry, i forgot to attach the file. so, here it is
here is the file. and i'm sorry for the typos. the title should be "destination host unreachable"
Martin L
Solved in https://community.cisco.com/t5/switching/destination-host-unreachable/td-p/4737860
you must click on Save Settings on Main GUI setup page !
Regards, ML
**Please Rate All Helpful Responses **
