HOW TO SORT BY DESCENDING Pkts THE OUTPUT OF SHOW IP CACHE FLOW AT CISCO ASR1001
Dear.
we are using at cisco router ASR1001 the command: show ip cache flow, to see the conversations at real time.
this is a partial output of this command:
SITEL_CHINCHON_CD90445#sh ip cache flow
IP packet size distribution (392661M total packets):
   1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
   .001 .315 .094 .040 .018 .014 .016 .009 .007 .004 .003 .005 .004 .004 .002
    512  544  576 1024 1536 2048 2560 3072 3584 4096 4608
   .002 .002 .006 .020 .423 .000 .000 .000 .000 .000 .000
IP Flow Switching Cache, 0 bytes
  44606 active, 155394 inactive, 3027049335 added
  31019322 ager polls, 2 flow alloc failures
  Active flows timeout in 1 minutes
  Inactive flows timeout in 10 seconds
  last clearing of statistics never
Protocol         Total    Flows   Packets Bytes  Packets Active(Sec) Idle(Sec)
--------         Flows     /Sec     /Flow  /Pkt     /Sec     /Flow     /Flow
TCP-Telnet    42397940      9.8        11   199    112.3       4.8      20.6
TCP-FTP        6547097      1.5        17    77     26.9       4.5      20.4
TCP-Frag          3644      0.0        52  1213      0.0       6.3      20.5
TCP-other  15117006861   3519.7        15   734  55862.7       2.3      20.8
UDP-DNS      908257379    211.4         1    75    253.7       0.5      21.0
UDP-NTP       24850212      5.7         1    79      7.3       0.5      21.0
IP-other       1852470      0.4        20   291      8.7      57.4       4.0
Total:     24501929564   5704.8        16   682  91423.4       2.6      20.7
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP         Pkts
gi0/0/0.3430  10.2.111.71     gi0/0/1       74.125.229.129  06 c895 0050    14
gi0/0/0.3430  10.11.5.45      gi0/0/1       199.188.236.240 06 f2b8 0bd4     27
gi0/0/1       200.37.161.41   gi0/0/0.3430  10.2.111.71     11 a6bc 4fb0       1
gi0/0/0.3430  10.17.101.240   gi0/0/1       91.145.79.244   11 b5fd c1da     1
gi0/0/1       8.27.148.253    gi0/0/0.3430  10.200.222.91   06 078f c98a     375
gi0/0/0.3430  192.168.13.33   gi0/0/1       132.245.13.210  06 c061 01bb     1
gi0/0/1       132.245.16.242  gi0/0/0.3430  10.110.111.66   06 01bb c074     1
gi0/0/0.3430  10.2.111.94     gi0/0/1       1.125.158.237   11 27db 13d2      18
What we need to do is to sort this output command by Pkts in descending order.
when we use the command: show ip cache flow | include Pkts....the router does not show nothing.
the command: ip flow-top-talkers is not supportes at this router.
can you help, please?
Attn.
0 Replies 0
