how to split tunnel VPN
iceman6684
All,
   i was able to setup split tunneling and phase 1 is successful however,  i am unable to ping any subnet that is being NAT. therefore,  trying to figure out how do i allow any VPN connection with a 192.168.20.X address can ping i.e 192.168.10.X.
John Blakley
You'll want to deny those addresses in the nat acl like
Deny ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
Do this on both ends. The source address for the acl should be on the box that you're doing this on. For instance, if you're putting the acl in the 192.168.10.x router, then you'd put the acl above.
Hth,
John
HTH, John *** Please rate all useful posts ***
John Blakley
Hth,
John
thanks that worked
