how to stack cbs350-12xs-uk
ciscokalpesh
We are getting 2 Cisco CBS350-12XS switches and want to stack them over the available 2 x 10 Gigabit copper ports. Can someone guide whether it is possible to stack over these copper ports?
Since these are shared ports, can we configure stacking using single 10G copper port between each switch and use the other 10G copper port for uplink to other Cisco switches?
Please guide.
K
3 Accepted Solutions
marce1000
 - You may find this document informative : https://www.cisco.com/c/en/us/support/docs/smb/switches/Cisco-Business-Switching/kmgmt2836-Stacking-Guidelines-for-CBS.html
 M.
Hello!
Well the documentation explains: Any 10G port of the switch can be used for stackingWhich in your case would mean you can use also the copper ports. I don't have a CBS350-12XS in front of me, but you can check the stacking configuration you will see if you are able to select the copper ports as stackin ports in the menu:Administration > Stack Management
Hope this helps,
BR
****Kindly rate all useful posts*****
For interchassis LACP you have to have the switches stacked.
BR
5 Replies 5
marce1000
 M.
Hello Marce,
Thanks for the useful link. I had gone through the link and one of the statement mentioned in it says, "The uplink network ports will be configured for stacking and the proper interconnecting small form-factor pluggable (SFP) cables support the stack channels." So SFP cables is must for stacking, but still want your expertise to confirm whether it can work with 10G Interface over copper as well ?
Also in order to use LACP between 2 pair of cisco switches, is it must that both pairs should be stacked or it can work with single stacked pair as well?
Please guide.
K
BR
Hello!
Hope this helps,
BR
ciscokalpesh
Hello Daniel,
Thanks for clarifying my doubts.
K
