04-09-2018 08:23 AM - edited 03-08-2019 02:34 PM
I have a small Lab with the following devices:
1. Windows Server - VLAN1
2. Linux Server - VLAN2
3. Switch sg300-10pp 10port PoE (Layer3)
4. Tp-Link Router VLAN3
Subnneting as below :
| Vlan1 | 14 | 14 | 192.168.1.0 | /28 | 255.255.255.240 | 192.168.1.1 - 192.168.1.14 | 192.168.1.15 |
| Vlan2 | 6 | 6 | 192.168.1.16 | /29 | 255.255.255.248 | 192.168.1.17 - 192.168.1.22 | 192.168.1.23 |
Vlan3 Trunk Port direct access to router |
2 | 2 | 192.168.1.24 | /30 | 255.255.255.252 | 192.168.1.25 - 192.168.1.26 | 192.168.1.27 |
The question is: Can I create VLANs as above on diffrent subnetting mask ?
How I can routing traffic to VLAN3/Router !? ex: 0.0.0.0/0 nexthop 192.168.1.26
* By the way I have basic information about networks.
Regards.
Solved! Go to Solution.
04-10-2018 01:07 AM
Hello
Can you confirm -
Do you have:
res
Paul
04-10-2018 04:14 PM
04-09-2018 09:52 AM
Yes you can create those vlans on your switch with the SVI associated to each vlan.
By default, when you have multiple svi, routing between them is done.
Now, vlan 3 will be your interconnect subnet between your switch and router.
Then on your switch (SG300) you need to add a default route. here an example in cli:
ip route 0.0.0.0/0 192.168.1.26
Every vlan after that, are able to access internet. You need to make sure that your router is natting all your subnets
04-09-2018 07:55 PM
Hi Francesco Molino,
Good Day,
First of all many thanks you for reply,
Unfortunately I have spent 4 hours of my time without getting a solution! each VLANs communicating with other successfully but stile unable to reach internet, only VLAN1 interfaces access to internet,
from my switch (L3) its self I try to ping router IP which is 192.168.1.241/28 from sources IPs VLAN2 & 4 still same issue (100% packets lost).
My attempts were:
1. I tried to used new subnetting to unify the mask for all subnet.
2. firmware upgraded & startup configurations erased for several times!
3. router DHCP disabled.
Your help will meet great & high appreciating!
Thanks!
MOI & NADIA!
04-09-2018 07:57 PM
04-10-2018 01:07 AM
Hello
Can you confirm -
Do you have:
res
Paul
04-10-2018 04:14 PM
04-09-2018 08:16 PM
I am thinking your router probably does not have a route back to your VLANs 2 and 4, only to VLAN1, as it has an IP address in it itself. can you check. ping from router to an IP address in vlan 2 and 4
Keep it simple and stick with all /24 if you are not strapped for IP addresses
04-12-2018 05:36 PM
After effort and try to understand, finally .. I found the solution! It is related to the static routing of the router! because the router does not know the indirect networks.
Steps to solve this issue for those who facing same situation in the future:
1.Assign IP for VLAN interface
2.Add default route to IP4 Routing from the switch e.x: 0.0.0.0/0 nexthop (Router IP)
3.From the router Add Static Routing to Interface (192.168.1.54) which directly connected to the router.
Thanks to God!, Thanks to everyone who helped me here!
My greetings!
| Static Routing | ||||||||||||||||||||||||
