How to telnet to Edge Switch
Hung Ho
Dear Experts,
I'm going to try configure on how to telnet to Edge switch but still no result. My Network topology is below:
- 1 Core Switch 3560
- 3 Edge Switch 2960
I'm configured 4 VLAN:
+ Vlan 19: 10.19.10.0/24
+ Vlan 20: 10.20.10.0/24
+ Vlan 21: 10.21.10.0/24
+ Vlan 22: 10.22.10.0/24
On each Vlan, I was assigned Vlan interface IP.
I'm using VTP mode (Server and client) to trunking VLAN and Core SW is standing a VTP Server. I can telnet to Core SW using VLAN Interface IP.
The question is how can I configure to telnet to Edge SW?
Has somebody help me on this?
Thanks in advance!
JH
snared04drummer
Are you missing an ip default-gateway command on the switches?
Garrett Smith
From looking at your topology, the configuration should work. You should be able to telnet into the edge switches from anywhere in the network using the ip addresses of the vlan interfaces on each switch.
What exactly is the issue you're experiencing?
Are you able to ping the switch ip addresses?
Looking forward to hearing from you
snared04drummer
Yeah, I missed the default-gateway on each Edge Switch. Now everything fine. Thanks your quick support
