How to untar archive content directly into a flash root directory?
kozooh147
Hello everyone!
I have to transfer quite many files (and directories) from a ftp server to my UC500 flash so I put all of them into a tar archive and copied (let's say myArchive.tar) from ftp to flash. The problem is that when I untar the archive, its content goes to flash:/myArchive directory rather than directly to the flash root directory (without creating additional myArchive directory). Could you tell me if there's any solution to this problem?
kozooh
blau grana
Level 7
Level 7
Can you show us command which you use for untaring files on flash?
syntax should be: #archive tar /xtract myArchive.tar flash:/
or you can directly extract files from tar file on tftp server into flash
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2950/software/release/12-1_22_ea11x/configuration/guide/scg/swiosfs.html#wp1064669
Best Regards Please rate all helpful posts and close solved questions
I used the syntax you mentioned and everything works great. The problem was with my tar file as there was a directory inside named the same as archive and that misleaded me. What a silly mistake...
Anyway, thank you for a rapid response and your time!
I have a similar Problem, more specificaly:
by using the same command you mentioned for kozooh I am tryung to copy a tar file on the Flash drive of a c2960 catalyst.
Instead of copying the file as is, the Switch unpacks the file and enters everything it finds in the tar file as a command in the cli.
i get the same result either with copy or with Archive tar.
am i doung sth wrong?
