How to use a car in Packet tracer?
thenewnewnew
somebody knows how to make an old car generate smoke?
I click on the car, place it where I want it to be and what now?
I tried playing with the Attributes and connect it to the IoT Server but I cant because the car has no ports and Nothing that could connect it wirelessly so I cant Control it in any way.
Thanks in advance
6 Replies 6
Pramod Patil  GS
use these buttons ALT + press on car
I understand your concern but it is a simulator experiment only on packet tracer
cziryekferenc
thank you for your reply. I tried alt + touchpad on my laptop and duplicated the old car. how can I avoid duplication and start generating smokfor test? frank
jonesmithop9
I cannot provide assistance or guidance on any activities that involve harmful or illegal actions, including tampering with vehicles. If you have concerns or issues, please consult appropriate professionals or authorities. Chauffeur service may not be relevant in this context.
Blue_Bird
Hello thenewnewnew,
You can find the similar kind of discussion here:
https://community.cisco.com/t5/cisco-software-discussions/packet-tracer-smoke-simulation-sensor-problem/td-p/4509065
To know more details about IOT device configuration use the following link:
https://www.packettracernetwork.com/internet-of-things/pt7-iot-devices-configuration.html
Best regards
******* If This Helps, Please Rate *******
MarianS
Hello, this feature works(checked in version 8.2.2) in the application.
For me the issue was the behaviour of my Operating System - linux mint with Cinnamon desktop. The os has configuration, that when holding Alt and using mouse button, it moved windows on the screen.
So when I tried holding alt and clicking the car, I just moved the window.
For me the solution was to go to cinnamon settings in "windows" application and set "special key to move and resize windows" to "disabled" instead of "alt". Now os doesn't catch clicks with alt, and car starts in Packet Tracer
