how to use encapsulation dot1q
hi guys,
when i use layer3 switch 3750 for intervlan routing but i dont use any of the encapsulation command then which encapsulation method it uses.
and if does not use dot1q encapsulation then how can i enable dot1q encapsulation in my network.
please help me in this topic
Narendra
5 Replies 5
nbv
Use router on stick or have one interface of router going to switch for each vlan
but i m using internal router and i just want to do only intervlan routing and it can be performed by using layer 3 switch.
and i want to know that by default which encapsulation method is used ,
and which command is used to verify the encapsulation used.
Narendra
dot1q is used when a switch interface is configured as a trunk. You have not told us that any switch port is configured as a trunk, and in what you have told us I do not see any requirement for trunking. You can certainly do inter vlan routing on the layer 3 switch without doing trunking.
Rick
Rick
why i hav sent a diagram of my with attachement
i m using two port as a trunk.
Narendra
This link shows the use of the command show interface trunk on a 3750 to show the encapsulation used:
http://www.cisco.com/en/US/partner/products/hw/switches/ps5023/products_configuration_example09186a00801cc828.shtml#veri
Rick
Rick
