OSPF Distance
kondratev
I have a simple network (see attachements). On R3 I have a route 10.10.10.0/24 from two sources: 1.1.1.1 and 2.2.2.2. R3 need to choose the route from 1.1.1.1. And I must do it with administrative distance for some reason. I can't change any OSPF metrics (the network is more complex, than at the pictue; I didn't draw all network elements for simplicity).
I have the following configuration at R3:
router ospf 1
dstance 140 2.2.2.2 0.0.0.0 NET
ip access-list standard NET
permit 10.10.10.0 0.0.0.255
But the distance of route from R2 is 110 as before.
And if I input the command 'dstance 255 2.2.2.2 0.0.0.0 NET', the route from R2 disappear as expected.
Could you tell me why does this command work correctly with distance 255 only?
2 Accepted Solutions
skarthic
This is an expected behavior for changes in AD within a process will not have an effect on the routes.
Please check the following link:http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCeh46993
So changing the AD will not influence in Path selection in OSPF.
Subramaniya Karthic.R
Please rate helpful posts.
It is an interesting link that Subramaniya Karthic.R provided. And it does explain your intial symptoms.
The explanation for what happens when you set the distance to 255 is a bit different. Most of the setting of AD are to compare prefixes learned from different sources. And the bug referenced in the link is quite clear that this is for comparing between multiple processes and should have no effect within a single routing process. The setting of AD to 255 is a special case of AD. Set to 255 is an indicator that the prefix is not trustworthy and should not be used in routing at all. This is why setting it to 255 changes the behavior.
It is perhaps a subtle bit of logic but setting AD to some value less than 255 helps guide the choice when there are two alternatives (and works between two routing processes) but setting AD to 255 assures that there will only be a single alternative to choose from.
Rick
Rick
Reza Sharifi
If you want r1 to be the exit point from r3, then make sure r3 to r1 interface has lower metric.
under the interface use
ip ospf cost xx
if both interfaces are for example 100MB, then you can raise the cost between r3 and r2, so r3 to r1 is prefered
ip ospf cost 10
Reza
skarthic
But if I input the command 'dstance 255 2.2.2.2 0.0.0.0 NET', AD influences Path selection. Or it's a bug also?
I have IOS 12.2(53)SE2. So there is no such bug in it.
Rick
Rick
