How to use the pipe command include A AND B
pfang_eho
I would use show pipe command to get some detailed output like show interface status | inculde text1 AND text2
For example,
"show interface status" include vlan "103" and "connected".
I tried multiple combination, it looks multi pipe only give you OR output but AND output.
Thanks in advance
2 Accepted Solutions
Jon Marshall
Peng
You are right in that the pipe command does not support the AND operator. You can do multiple OR commands eg.
sh int status | include Vlan | connected
but the above would show any interfaces that began with Vlan and also any connected interfaces whether or not they were vlan interfaces.
You cannot do an AND ie. show me all vlan interfaces that are also connected
note the above is a bad example because all vlan interfaces on a L3 switch should show as connected but you get the meaning.
I asked a while back on these forums whether there were any plans to add the AND operator and was told there weren't and that probably there wouldn't be in future because IOS now supports TCL and this has a much more extensive regex engine which you can use.
Jon
ankugarg
Level 3
Level 3
Hi Peng,
You can use "sh int status | inc connected.*103" or "sh int status | inc 103.*connected",depending on whether  connexted apperas first or 103...I think connected appears first.
Paste the output of full command if it doesn't get the required output..We will refine the regex.
-Ankur
13 Replies 13
Jon Marshall
Peng
Jon
I am not sure but somebody told me that we can use regular expressions also after pipe ?
I just tried...It works
3-mem-stack#sh ip int br | inc Port.*up
Port-channel2          unassigned      YES unset  up                    up
3-mem-stack#
ankugarg,
This was very helpful.  I know use the following command a lot:
Switch#sho ip int bri | in ^Giga.*up.*up
Thank you for this extremely helpful information.
ankugarg
Level 3
Level 3
Hi Peng,
-Ankur
Thanks Ankur and Jon,
You guys are QUICK, yes Regrex did the trick. THANK YOU..
01-core-A-103-20#sh int status | inc connected.*103
Gi11/15 Primary Nic SSHMDF connected    103         a-full a-1000 10/100/1000BaseT
Gi11/27 reserved for NSP D connected    103         a-full a-1000 10/100/1000BaseT
Gi11/32 SSHRSS0BU301 Red H connected    103         a-full  a-100 10/100/1000BaseT
Gi11/33 SSHUAA0B0001 Red H connected    103         a-full  a-100 10/100/1000BaseT
Gi11/35 Core SQL Server Ge connected    103         a-full a-1000 10/100/1000BaseT
Gi12/2  Core SQL Server Ge connected    103           full   1000 10/100/1000BaseT
Gi12/14 NetIQ Security Man connected    103           full   1000 10/100/1000BaseT
Gi12/15 DC1 Root Server    connected    103         a-full a-1000 10/100/1000BaseT
01-core-A-103-20#
01-core-A-103-20#sh int status | inc 103.*connected
Gi12/16 01-CA-103-24 G1/0/ connected    trunk       a-full a-1000 10/100/1000BaseT
Good one Ankur!
Jochen Reinecke
Sure you can.
Try something like this:
show vl br | include (111|222)
Best regards!
best regards,
Just to add to the helpful commands that have been posted.
sho interfaces status | count connected
Number of lines which match regexp = 153
sho interfaces status | count notconnect
Number of lines which match regexp = 92
sho interfaces status | count connected|notconnect
Result of both.
Felipe,
 What device and version of code are you running?
Kind Regards,
Ryan
Hi Ryan,
I have tried it on the following devices with the following IOS versions.
WS-C3850-48P - Version 16.3.5b
WS-C4510R+E - Version 03.09.02.E
WS-C3750X-48 - Version 15.0(2)SE, RELEASE SOFTWARE (fc1)
WS-C2960G-8TC-L - Version 12.2(58)SE1, RELEASE SOFTWARE (fc1)
FA
maurizio.s
I think I may have found an "and" option. It seems like you will get different output depending on how the command is constructed.
For example. I did the following
sh start | i priv|cable       - This shows me all lines that match prive OR cable
However if I enter
sh start | i priv| cable    - I get the result of pirv AND cable
privilege exec level 3 test cable-diagnostics tdr interface
privilege exec level 3 show cable-diagnostics tdr interface
@maurizio.s It's still just a regex and not an AND condition.
The way that gets interpreted is as `priv| cable` which means it will include any line that contains either "priv" or " cable" (with the leading space), which is why it appeared to work for that specific combination with that device's configuration at that time.
The entire line after the include, section, or exclude directive is interpreted as one big regex in which any non-leading and non-trailing whitespace is respected (you can make leading and trailing whitespace match by surrounding an expression or sub-expression with parentheses).
Any additional pipe characters represent a regex OR (substitution) directive, meaning it can take the sub-expression that's on the left or the right of it. I will include an example that can be tested on any device at the end.
However, that points out an important concept: Since you can include whatever you want in your expression, coming up with a more specific regex that will naturally not include what you don't want is often possible. In this instance, you would have gotten the same output with `show run | i ( cable)`. Had there been any other lines with the sequence " cable" in them, they also would have shown up, even without "priv".
I do not know what specific regex grammar IOS(-X(E|R)) uses, but I'd assume (based on Cisco doing everything in Java) that it's either Java regex or PCRE|PCRE2. It seems to behave similarly to PCRE2, supporting most syntax I've ever tried.
Unfortunately, it does not appear to support negative lookahead/lookbehind, which would allow for exclusions of sub-expressions. It does support some directives containing the question mark, if you enter it properly and use a backslash to escape the parentheses (depending on the expression), but the (?<!) and (?!) (negative lookbehind and negative lookahead, respectively) do not appear to work in any test I've performed, as of IOS-XE 17.12.04b.
Example showing behavior of the suggested expression.
Configuration (using a banner for free-form text entry):
#show run | b banner slip-ppp
banner slip-ppp ^C
privilege something-cable-something
privilege cable-something
privilege something
cable something
cable privilege
 cable something
 cable privilege
privilegecable
^C
#show run | i priv| cable
privilege something
cable privilege
 cable something
 cable privilege
privilegecable
(Don't forget to remove the banner with `no banner slip-ppp`)
As you can see, any line that contained "priv" or " cable" was included, as would be expected from a regex like this.
Specifically, the `cable something` (no leading whitespace) line was excluded, since it didn't match either condition.
