How to view connections on a specific interface??
jacob6000
I have a 2801 router (12.4) with two lan interfaces and one T-1 that is dedicated for voip traffic. I am seeing an usual amount of traffic on the T-1. How can I see all the flows/connections for the serial interface (T-1) specifically?  Top talkers?
Thank you,
John Blakley
Yes, top talkers. The quickest way that I know of is:
ip flow-top-talkers
sort bytes
top 10
int s0/0
ip flow egress
ip flow ingress
Then "show ip flow top"
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Thank you John. I'm actually doing that exact thing but I'm confused by the output.
ex:
#sh ip flow top-talkers
SrcIf         SrcIPaddress    DstIf         DstIPaddress    Pr SrcP DstP Bytes
Local         154.124.x.x  Se0/1/0*         68.128.110.100 32 3110 44CF    10M
Tu21          192.168.1.125   Vl10          192.168.2.236   06 D091 0814  4601K
Vl10          192.168.2.236   Tu21*         192.168.1.125   06 0814 D08E  4203K
Fa0/0         x.x.x.x    Vl10               x.x.x.x    06 01BB F516  1096K
Vl10          x.x.x.x    Fa0/0*             x.x.x.x    06 F516 01BB   837K
Se0/1/0       49.75.140.1     Vl10          154.124.x.x  32 C8B3 EC6B   710K
Local         154.124.x.x  Se0/1/0*         49.75.140.1     32 E048 8F57   432K
Tu21          192.168.1.100   Vl10          192.168.2.6     11 0000 0000   324K
Vl10          x.x.x.x    Fa0/0*             132.245.15.98   06 EDAD 01BB   303K
Vl10          x.x.x.x    Fa0/0*             x.x.x.x   06 FAB2 01BB   141K
10 of 10 top talkers shown. 113 flows processed.
Now take this one entry. Does the entry below mean that 192.168.2.241 is the actual inside address making a connection to the outside world. This addess isn't allowed to go outside this is why I need confirmation. I have an explicit NAT acl to allow only specific address through  the 154.124.x.x interface (T-1) and this isn't one of them.
Se0/1/0        49.75.140.1     Vl10           154.124.x.x  32 00  10     719K
C8B3 /32 0                     EC6B /24 0     192.168.2.241         242   809.9
hi,
i would suggest to download a netflow traffic analyzer tool to better understand the output.
http://wannabelab.blogspot.com/2013/11/configuring-netflow.html
alternatively, enable ip accounting on the LAN port.
int fx
ip accounting output-packets
sh ip accounting
