Which cisco model Switch can support 20 Port 40 Gbps and 48 Port 10 Gbps
MOHAMMAD RAZA
Hi all,
could you suggest me Which cisco Switch can support 20 Port 40 Gbps and 48 Port 10 Gbps.
Arumugam Muthaiah
Please see the detail below,
6500 switch:
The Cisco Catalyst 6904 4-Port 40 Gigabit Ethernet Fiber Module
Part number WS-X6904-40G-2T
The Cisco Catalyst 6900 Series 4-Port 40 Gigabit Ethernet Fiber Module is compatible only with Cisco Catalyst 6500 Supervisor Engine 2T
32 x 40 Gigabit Ethernet ports or 128 (+2 Supervisor Uplink) 10 Gigabit Ethernet ports (6509-E chassis)
44 x 40 Gigabit Ethernet ports or 176 (+2 Supervisor Uplink) 10 Gigabit Ethernet ports (6513-E chassis)
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/data_sheet_c78-696623.html
Nexus 7700
Cisco Nexus 7700 F3-Series 24-Port 40 Gigabit Ethernet Module Data Sheet
Part number: N77-F324FQ-25
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/data_sheet_c78-728410.html
Cisco Nexus 7700 F2-Series Enhanced 48-Port Fiber 1 and 10 Gigabit Ethernet Module Data Sheet
Part number: N77-F248XP-23E
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/data_sheet_c78-728409.html
Please feel free to call me if you need more clarification.
Aru
Regards, Aru *** Please rate if the post useful ***
Rasika Nayanajith
6800 Series switches also support 40G interfaces (actually it is running with Sup2T). As Aru highlighted in the above only 4x40G port line card (WS-X6904-40G) available today.
We may get 8x40G or (32x10G) line card with this 6800 series without having to go for any Sup2T Upgrade.
Here is the data sheet of this 6800 series switch
http://www.cisco.com/en/US/prod/collateral/switches/ps10902/ps715/ps13195/data_sheet_c78-728229.html
Rasika
**** Pls rate all useful responses ****
Many many thanks to both guys,
I have already make BOQ on C6807-XL.
That's great..
If this answer to your qurey then mark this thread as "answered" and rate all helpful responses. That will help others to find a answer to a similar query
Rasika
