HP Access Point 530 Power ON and OFF on Cisco Catalyst 3560 POE - 48 Switch
JOSIAH BOZIAH
HP Access Point 530 Power ON and OFF on Cisco Catalyst 3560 POE - 48 Switch. The HP access Point keeps powering up and then it Powers down. Any help out there will greatly appreciated. does anyone know if my Cisco switch is POE+?
6 Replies 6
Leo Laohoo
The command "sh power inline" will tell you whether or not your switch is PoE/PoE+.
What is the exact model of your switch?
Catalyst 3560 SeriesPOE-48
Model  WS-C3560-48PS      SW Version  12.2(25)SEC           SW Image  C3560-IPBASEK9-M
Plain 3560, so this means 15.4w maximum power per port.  This model will NOT support PoE+.
Could that explain why my HP Access Point 530 Powers UP and then Powers Down?
Nope.  I don't know anything about HP's APs.
Your switch doesn't support TDR so I can't say it's due to faulty cabling (and you haven't eliminated faulty cabling).
Try connecting the APs directly to the switch.  What power requirement(s) does the AP need?   What configurations do the APs require?
manga#show power inline
Available:370.0(w)  Used:0.0(w)  Remaining:370.0(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Fa0/1     auto   off        0.0     n/a                 n/a   15.4
Fa0/2     auto   off        0.0     n/a                 n/a   15.4
Fa0/3     auto   off        0.0     n/a                 n/a   15.4
Fa0/4     auto   off        0.0     n/a                 n/a   15.4
Fa0/5     auto   off        0.0     n/a                 n/a   15.4
Fa0/6     auto   off        0.0     n/a                 n/a   15.4
Fa0/7     auto   off        0.0     n/a                 n/a   15.4
Fa0/8     auto   off        0.0     n/a                 n/a   15.4
Fa0/9     auto   off        0.0     n/a                 n/a   15.4
Fa0/10    auto   off        0.0     n/a                 n/a   15.4
Fa0/11    auto   off        0.0     n/a                 n/a   15.4
Fa0/12    auto   off        0.0     n/a                 n/a   15.4
Fa0/13    auto   off        0.0     n/a                 n/a   15.4
Fa0/14    auto   off        0.0     n/a                 n/a   15.4
Fa0/15    auto   off        0.0     n/a                 n/a   15.4
Fa0/16    auto   off        0.0     n/a                 n/a   15.4
Fa0/17    auto   off        0.0     n/a                 n/a   15.4
Fa0/18    auto   off        0.0     n/a                 n/a   15.4
Fa0/19    auto   off        0.0     n/a                 n/a   15.4
                            (Watts)
Fa0/20    auto   off        0.0     n/a                 n/a   15.4
Fa0/21    auto   off        0.0     n/a                 n/a   15.4
Fa0/22    auto   off        0.0     n/a                 n/a   15.4
Fa0/23    auto   off        0.0     n/a                 n/a   15.4
Fa0/24    auto   off        0.0     n/a                 n/a   15.4
Fa0/25    auto   off        0.0     n/a                 n/a   15.4
Fa0/26    auto   off        0.0     n/a                 n/a   15.4
Fa0/27    auto   off        0.0     n/a                 n/a   15.4
Fa0/28    auto   off        0.0     n/a                 n/a   15.4
Fa0/29    auto   off        0.0     n/a                 n/a   15.4
Fa0/30    auto   off        0.0     n/a                 n/a   15.4
Fa0/31    auto   off        0.0     n/a                 n/a   15.4
Fa0/32    auto   off        0.0     n/a                 n/a   15.4
Fa0/33    auto   off        0.0     n/a                 n/a   15.4
Fa0/34    auto   off        0.0     n/a                 n/a   15.4
Fa0/35    auto   off        0.0     n/a                 n/a   15.4
Fa0/36    auto   off        0.0     n/a                 n/a   15.4
Fa0/37    auto   off        0.0     n/a                 n/a   15.4
Fa0/38    auto   off        0.0     n/a                 n/a   15.4
Fa0/39    auto   off        0.0     n/a                 n/a   15.4
Fa0/40    auto   off        0.0     n/a                 n/a   15.4
Fa0/41    auto   off        0.0     n/a                 n/a   15.4
                            (Watts)
Fa0/42    auto   off        0.0     n/a                 n/a   15.4
Fa0/43    auto   off        0.0     n/a                 n/a   15.4
Fa0/44    auto   off        0.0     n/a                 n/a   15.4
Fa0/45    auto   off        0.0     n/a                 n/a   15.4
Fa0/46    auto   off        0.0     n/a                 n/a   15.4
Fa0/47    auto   off        0.0     n/a                 n/a   15.4
Fa0/48    auto   off        0.0     n/a                 n/a   15.4
