HP Procurve 9300 switch (Foundry) to Cisco Connectivity at IP layer on 10GE
astanislaus
Level 2
Level 2
Layer 2 is up, but can't ping even a directly connected interface from HP Procurve 10GE port to Cisco 10GE port.
jsivulka
Level 5
Level 5
I would recommend you to configure 'Active' mode on either HP procurve end or switch end for ether channel to work as desired.
The following URL will help you:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_37_se/configuration/guide/swethchl.html#wp1275918
Giuseppe Larosa
Hello Alphonse,
I've noticed that in your sh int te4/1
Last input 00:14:40, output 00:00:40, output hang never
It looks like it is not receiving any frame.
try
sh ip arp 10.34.252.26 on C6506
do you see an entry ?
also to help ARP
int te4/1
ip proxy-arp
ip redirects
Hope to help
Giuseppe
