HRSP between two 6509 not working
I have two 6509 interconnected with a trunk interface. On this interface, with other vlan, is active the vlan 120.
The vlan 120 is configured in HSRP:
6509 Primary
interface Vlan120
 description "LAN 120"
 ip address 192.168.120.2 255.255.255.0
 ip access-group XBSCENTRAL-120-in in
 ip flow ingress
 standby 120 ip 192.168.120.1
 standby 120 priority 90
 standby 120 preempt
end
6509 Backup
interface Vlan120
 description  description "LAN 120"
 ip address 192.168.120.3 255.255.255.0
 ip flow ingress
 standby 120 priority 110
 standby 120 preempt
end
This is the output of the "sh standby vlan 120"
6509 Primary
core1-pr#sh standby vlan 120
Vlan120 - Group 120
  State is Active
    8 state changes, last state change 00:36:40
  Virtual IP address is 192.168.120.1
  Active virtual MAC address is 0000.0c07.ac78
    Local virtual MAC address is 0000.0c07.ac78 (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 0.320 secs
  Preemption enabled
  Active router is local
  Standby router is unknown
  Priority 90 (configured 90)
  IP redundancy name is "hsrp-Vl120-120" (default)
6509 Backup
core1-bk#sh standby vlan 120
Vlan120 - Group 120
  State is Active
    11 state changes, last state change 00:23:19
    Next hello sent in 0.480 secs
  Preemption enabled
  Priority 110 (configured 110)
The vlan 120 is active on both 6509 and also the interfaces are active. I can reach without problem the phisycal interfaces of the 6509.
For examples: with extended ping command I can reach 192.168.120.3 from 192.168.120.2, and viceversa.
Other vlan configured like the vlan 120 are working without this problem.
I don't understand why the HSRP protocol in vlan 120 can'nt detect the stand-by router.....
2 Accepted Solutions
mohseen patel
Hi Fabrizio,
Can you also paste configuration of access list which you have in there.
Br.
Mohseen Patel
Hi Fabrizio,
Could you please show the access-list  XBSCENTRAL-120-in configuration on both nodes
M
mohseen patel
Hi Fabrizio,
Br.
Mohseen Patel
Hi Fabrizio,
M
Hi, thank you for both answers.
I resolved the issue... I don't know why in the ACL only IP traffic was open.
I added the rule: permit udp 192.168.120.0 0.0.0.255 host 224.0.0.2
and now the HSRP works very well.
Thank you.
