%HSRP-4-BADAUTH
ashleyreed4218
Hello All:
Happy Thanksgiving!
Can anyone point me in the right direction of this error on my switch:
%HSRP-4-BADAUTH: Bad authentication from 192.168.30.2, group 30, remote state Active
I don't know enough about HSRP to diagnose what the error could be.
Thank you in advance,
Ashley
3 Accepted Solutions
John Blakley
Ashley,
This generally means that the standby group is using authentication, but the other side isn't. Check to see if authentication is configured between these two devices. If you want, you can post the configuration here as well.
HTH,
John
HTH, John *** Please rate all useful posts ***
switch1:
int vlan 30
no standby 30 authentication
or better:
switch2:
int vl30
standby 30 auth Cisco30
Regards.
Alain
You should have it configured on both switches, but if you don't want authentication, then you can remove it from both switches.
HTH,
John
7 Replies 7
John Blakley
Ashley,
HTH,
John
Thanks John:
How can I change the authentication? (Sorry I have never really worked with HSRP)
Here is more info:
Switch1#
Nov 21 14:24:57.479: %HSRP-4-BADAUTH: Bad authentication from 192.168.30.3, group 30, remote state Active
interface Vlan30
description LAN1 Subnet
ip address 192.168.30.2 255.255.255.0
ip igmp query-interval 20
standby 30 ip 192.168.30.1
standby 30 timers 1 3
standby 30 priority 255
standby 30 preempt
standby 30 authentication Cisco30
Switch2#
Nov 21 13:57:42.138: %HSRP-4-BADAUTH: Bad authentication from 192.168.30.2, group 30, remote state Active
interface Vlan30
ip address 192.168.30.3 255.255.255.0
standby 30 priority 110
standby 30 preempt
switch1:
int vlan 30
or better:
switch2:
int vl30
Regards.
Alain
Thank you,
But do I need to have authentication on both switches?
HTH,
John
Thank you, the error is gone and now I have:
%HSRP-5-STATECHANGE: Vlan30 Grp 30 state Speak -> Standby
Is this good ?
Thanks guys,
Ashley
If this is the router that you want to serve as the backup router, then this is perfect
