HSRP and frame flooding in PT
adrmru
I created mesh topology to learn/exercise features for exam and among others there is HSRP.
HSRP looks to work to fine and do the job as intended. My concern is about frames flooding out of all interfaces. Switch should learn mac address of HSRP virtual interface after few frames but not in my case. After countinous ping it's flooding all the time and I was concern about bandwidth usage. It should work like this or I just missconfigured something? Maybe PT bug?
Just checked DSW1 and DSW2 HSRP virtual mac address and on both it is the same. It should be, right? I wanted also to divide logic topology with PVST+ and it looks to work fine to. Vlan2 root switch is DSW1 and for vlan1 and vlan3 there is DSW2.
DSW1#show standby
Vlan2 - Group 2
  State is Active
    5 state changes, last state change 00:00:37
  Virtual IP address is 192.168.0.1
  Active virtual MAC address is 0000.0C07.AC02
    Local virtual MAC address is 0000.0C07.AC02 (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.034 secs
  Preemption enabled
  Active router is local
  Standby router is unknown
  Priority 200 (configured 200)
  Group name is hsrp-Vl2-2 (default)
DSW2#show standby
Vlan2 - Group 2
  State is Standby
    18 state changes, last state change 00:08:10
    Next hello sent in 1.958 secs
  Preemption disabled
  Active router is 192.168.0.2, priority 200 (expires in 7 sec)
  Standby router is local
  Priority 100 (default 100)
DSW1 HSRP config:
interface Vlan2
 mac-address 0001.638c.a301
 ip address 192.168.0.2 255.255.255.0
 standby 2 ip 192.168.0.1
 standby 2 priority 200
 standby 2 preempt
interface Vlan3
 mac-address 0001.638c.a302
 ip address 172.16.0.3 255.255.255.0
 standby 3 ip 172.16.0.1
DSW2 HSRP config:
interface Vlan2
 mac-address 00d0.d35a.5601
 ip address 192.168.0.3 255.255.255.0
interface Vlan3
 mac-address 00d0.d35a.5602
 ip address 172.16.0.2 255.255.255.0
 standby 3 priority 200
 standby 3 preempt
PT oftentimes doesn't work the way a 'real' network would. Can you post the .pkt project file ?
Link to PT file below, if you want to check and give some tips:
http://s000.tinyupload.com/?file_id=03145687335530386014
