04-07-2017 07:19 AM - edited 03-08-2019 10:06 AM
Hi friends, i'm actually learning about HSRP protocol.
I need to know in packet tracer:
-How to reboot HSRP process in a HSRP group ?
-How to force one router to be an active router in a HSRP group ( i've already tried to change the priority but it's doesn't work) ?
-Why if i write that Router(config-if)#standby 1 track Serial 0/1, and Serial 0/0 change status to down , it's doesn't decrease by ten the priority ?
There's my pkt file if you need.
Thanks for help.
Kevin
Solved! Go to Solution.
04-07-2017 10:41 AM
-How to force one router to be an active router in a HSRP group ( i've already tried to change the priority but it's doesn't work)?
A: You can use el command standby 1 preetemp in the router you want to be the active. If you do not use the preempt standby command in the configuration of a router, that router will not become the active router, even if its priority is higher than that of the remaining routers.
A: No, the priority only changes when the interface Serial0/1 goes down and when goes back to up state, because this interface has the track Serial0/0 hasn't.
--Remember mark and rate useful answers.---
04-07-2017 12:13 PM
Here is the simulation, corrected.
---Remember mark and rate useful answers.---
04-07-2017 10:41 AM
04-07-2017 10:56 AM
Thanks for your help ,
Actually i've changed the track for Serial 0/0 by command: Router(config-if)#standby 1 track Serial 0/0
and when Serial 0/0 goes down it's decrease by ten the priority !
but even with this decrease, the router stays like active router instead standby router !
Maybe i can fix that by restart hsrp process but i don't know how !
04-07-2017 11:01 AM
Have you added preempt on both routers as already suggested. Even if the standby router now has a higher priority it won't take over unless you have added that command to your HSRP configuration.
Jon
04-07-2017 11:02 AM
i'll try this.
I've forgot this input on this on both routers
04-07-2017 11:16 AM
Hello Kevin!
What priority did you configure in your routers? are you using the default priority on both?
04-07-2017 11:38 AM
Hello anaid
Actually yes i've used the default priority on both routers.
04-07-2017 12:13 PM
04-19-2017 10:07 AM
Hi, sorry i was travelling , i've not tested your corrected simulation,
today i've tried it but it doesn't works, because the file is incompatble with the last version of packet tracer, can you try to send again another simulation made with the last version of packet tracer please ?
Kevin
04-19-2017 11:24 AM
Hello!
It's strange because I have the last version of packet tracer and I only modified your own simulation.
Here are the configuration of your routers (corrected):
ROUTER2
Router#show run
Building configuration...
Current configuration : 1224 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 192.168.0.254 255.255.255.0
duplex auto
speed auto
standby version 2
standby 1 ip 192.168.0.250
standby 1 priority 105
standby 1 preempt
standby 1 track Serial0/0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0
ip address 172.16.0.14 255.255.255.252
interface Serial0/1
no ip address
clock rate 2000000
shutdown
interface Serial0/2
no ip address
clock rate 2000000
shutdown
interface Serial0/3
no ip address
clock rate 2000000
shutdown
interface FastEthernet1/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet1/1
no ip address
duplex auto
speed auto
shutdown
router ospf 1
log-adjacency-changes
passive-interface FastEthernet0/0
network 192.168.0.0 0.0.0.255 area 0
network 172.16.0.12 0.0.0.3 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.13
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
ROUTER3:
Router#SHOW RUN
Current configuration : 1170 bytes
version 12.2
hostname Router
ip cef
no ipv6 cef
ip address 192.168.0.253 255.255.255.0
duplex auto
speed auto
standby version 2
standby 1 preempt
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0
no ip address
clock rate 2000000
shutdown
interface Serial0/1
ip address 172.16.0.18 255.255.255.252
interface Serial0/2
no ip address
clock rate 2000000
shutdown
interface Serial0/3
no ip address
clock rate 2000000
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
router ospf 1
network 172.16.0.16 0.0.0.3 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.17
line con 0
line aux 0
line vty 0 4
login
end
04-21-2017 01:43 AM
indeed it's really strange, but thanks for your help i'll try that , i will send you a feedback when i've finish to test.
Regards.
Kevin
