HSRP and STP failed after adding route to inside network
Salute, dear community!!
I have two 2921 routers running HSRP.
Here is configrurations of routers:
C2921UP (HSRP Active)
C2921UP#sh standby
GigabitEthernet0/2 - Group 0 (version 2)
  State is Active
    2 state changes, last state change 00:34:00
    Track object 13 state Up
  Virtual IP address is 192.168.12.100
  Active virtual MAC address is 0000.0c9f.f000
    Local virtual MAC address is 0000.0c9f.f000 (v2 default)
  Hello time 1 sec, hold time 3 sec
    Next hello sent in 0.640 secs
  Preemption enabled
  Active router is local
  Standby router is 192.168.12.2, priority 95 (expires in 2.608 sec)
  Priority 100 (default 100)
  Group name is "HSRP_GROUP" (cfgd)
C2921UP#sh ip route
Gateway of last resort is X.X.X.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via X.X.X.1
S     192.168.10.0/24 [1/0] via 192.168.12.3
      192.168.11.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.11.0/24 is directly connected, GigabitEthernet0/0
L        192.168.11.31/32 is directly connected, GigabitEthernet0/0
      192.168.12.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.12.0/24 is directly connected, GigabitEthernet0/2
L        192.168.12.1/32 is directly connected, GigabitEthernet0/2
      X.X.X.0/24 is variably subnetted, 2 subnets, 2 masks
C        X.X.X.0/24 is directly connected, GigabitEthernet0/1
L        X.X.X.83/32 is directly connected, GigabitEthernet0/1
C2921UP (HSRP Standby)
C2921DOWN#sh standby
  State is Standby
    4 state changes, last state change 00:26:57
    Next hello sent in 0.384 secs
  Preemption disabled
  Active router is 192.168.12.1, priority 100 (expires in 2.944 sec)
    MAC address is b0fa.ebd2.1f42
  Standby router is local
  Priority 95 (configured 95)
C2921DOWN#sh ip route
Gateway of last resort is not set
{There is no route to the 192.168.10.0. I'll get to that later yet}
L        192.168.11.32/32 is directly connected, GigabitEthernet0/0
L        192.168.12.2/32 is directly connected, GigabitEthernet0/2
And I have two ASA-5525-X running in Active/Standby failover mode. Here is confugration:
FWUP# sh running-config
: Saved
ASA Version 8.6(1)2
hostname FWUP
names
interface GigabitEthernet0/0
description To-Core-Stack-Gig1/0/4
channel-group 1 mode on
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
description To-Core-Stack-Gig2/0/4
no nameif
no security-level
no ip address
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/7
description LAN/STATE Failover Interface
interface Management0/0
nameif management
security-level 100
ip address 192.168.11.33 255.255.255.0 standby 192.168.11.34
management-only
interface Port-channel1
port-channel load-balance dst-ip
nameif inside
security-level 100
ip address 192.168.10.1 255.255.255.0 standby 192.168.10.2
interface Port-channel1.9
shutdown
vlan 9
nameif Administrators
security-level 100
ip address 192.168.9.1 255.255.255.0 standby 192.168.9.2
interface Port-channel1.12
vlan 12
nameif outside
security-level 0
ip address 192.168.12.3 255.255.255.0 standby 192.168.12.4
interface Port-channel1.52
vlan 52
nameif DMZ
security-level 50
ip address 192.168.52.1 255.255.255.0 standby 192.168.52.2
ftp mode passive
dns server-group DefaultDNS
access-list OUT_IN extended permit ip any any
pager lines 24
logging asdm informational
failover
failover lan unit secondary
failover lan interface fo GigabitEthernet0/7
failover replication http
failover mac address Port-channel1 7cad.746f.65cc 7cad.746f.6608
failover mac address Management0/0 7cad.746f.65c7 7cad.746f.6603
failover link fo GigabitEthernet0/7
failover interface ip fo 10.254.254.253 255.255.255.252 standby 10.254.254.254
monitor-interface outside
monitor-interface DMZ
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
access-group OUT_IN in interface inside
access-group OUT_IN in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.12.100 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
: end
And one else configuration  of stack of two switches cat3750-x:
hostname C3750-Core
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750x-24
switch 2 provision ws-c3750x-24
system mtu routing 1500
no ip domain-lookup
spanning-tree mode pvst
spanning-tree vlan 1,9,12,52 priority 24576
vlan internal allocation policy ascending
ip ssh time-out 60
ip ssh authentication-retries 2
lldp run
description To-FWUP
switchport mode trunk
interface Port-channel2
description To-FWDOWN
interface Port-channel3
description To-C2960
switchport trunk allowed vlan 1-11,13-4094
interface Port-channel10
description To-FABRIC-A
interface Port-channel20
description To-FABRIC-B
interface FastEthernet0
description MANAGEMENT_L3_PORT
ip address 192.168.11.14 255.255.255.0
no ip route-cache cef
no ip route-cache
interface GigabitEthernet1/0/1
description C2921UP-Gig0/0
interface GigabitEthernet1/0/2
description C2921UP-Gig0/2
switchport access vlan 12
switchport mode access
interface GigabitEthernet1/0/3
description C2921UP-Gig0/1
interface GigabitEthernet1/0/4
description To-FWUP-Gig0/0
interface GigabitEthernet1/0/5
description To-FWDOWN-Gig0/0
channel-group 2 mode on
interface GigabitEthernet1/0/6
description To-FWUP-Mngmnt
interface GigabitEthernet1/0/24
description To-C2960-Gig-1
channel-group 3 mode on
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface GigabitEthernet2/0/1
description C2921DOWN-Gig0/0
interface GigabitEthernet2/0/2
description C2921DOWN-Gig0/2
interface GigabitEthernet2/0/3
description C2921DOWN-Gig0/1
interface GigabitEthernet2/0/4
description To-FWUP-Gig0/1
interface GigabitEthernet2/0/5
description To-FWDOWN-Gig0/1
interface GigabitEthernet2/0/6
description To-FWDOWN-Mngmnt
interface GigabitEthernet2/0/24
description To-C2960-Gig-2
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface Vlan1
ip address 192.168.10.3 255.255.255.0
interface Vlan9
ip address 192.168.9.3 255.255.255.0
interface Vlan12
ip address 192.168.12.200 255.255.255.0
interface Vlan52
ip address 192.168.52.3 255.255.255.0
ASA Active/standby cluster is working brilliant!
HSRP is working too.
I can ping HSRP Virtual IP 192.168.12.100 from outside interface of ASA-cluster. And I can ping
HSRP Virtual IP 192.168.12.100 from inside host (192.168.10.62). But! When I add static route on standby HSRP-router (C2921-DOWN) to 192.168.10.0 through 192.168.12.3.
C2921DOWN(config)#ip route 192.168.10.0 255.255.255.0 192.168.12.3
after few seconds my network goes down. It seems loop in the network. I do "show int gig1/0/2 or gig2/0/2 or any portchannel" in
C3750-Core and I see many million packets per second! When I delete this route from standbyHSRP-router  network goes up.
Please. Where is the dog is buried?
Problem was solved. Deploying "permit ip any any" on outside interface was too bad idea.
