Cisco AIR-LAP1252AG-A-K9
djelizondo
I am working with a AIR-LAP1252AG-A-K9. It currently has a password set for it that I do not know.
The reset to factory defaults instructions off the cisco software configuration guide simply states "when the access point reboots and the summary status screen appears, type :resetall, and press enter." my understanding from the manual you have 2 mintues to do this once you have a cli prompt and after the ap has booted it should display a status screen.  I however only seem to get a login screen.
Can someone please help me reset this AP to factory defaults so that I may test and configure it?
IOS Bootloader - Starting system.
Xmodem file system is available.
flashfs[0]: 153 files, 8 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31868928
flashfs[0]: Bytes used: 8750080
flashfs[0]: Bytes available: 23118848
flashfs[0]: flashfs fsck took 17 seconds.
Reading cookie from flash parameter block...done.
Base Ethernet MAC address: 1c:df:0f:c3:38:ae
Loading "flash:/c1250-k9w7-mx.124-10b.JDA3/c1250-k9w7-mx.124-10b.JDA3"...#######
File "flash:/c1250-k9w7-mx.124-10b.JDA3/c1250-k9w7-mx.124-10b.JDA3" uncompressed
and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1250 Software (C1250-K9W7-M), Version 12.4(10b)JDA3, RELEAS
E SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 07-Jun-09 03:50 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01000000
Initializing flashfs...
flashfs[1]: 153 files, 8 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 31868928
flashfs[1]: Bytes used: 8750080
flashfs[1]: Bytes available: 23118848
flashfs[1]: flashfs fsck took 4 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Warning:  the compile-time code checksum does not appear to be present.
Radio 1 A600 8000 0 0 A8030000 30
Radio 1 A600 8000 0 0 B8030000 13
tx_paks 1293
tx_paks 646
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1252AG-A-K9   (PowerPC 8349) processor (revision C0) with 49142K/16
384K bytes of memory.
Processor board ID FTX144390KE
PowerPC 8349 CPU at 533Mhz, revision number 0x0031
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 1C:DF:0F:C3:38:AE
Part Number                          : 73-10425-06
PCA Assembly Number                  : 800-27630-06
PCA Revision Number                  : B0
PCB Serial Number                    : FOC14390WYP
Top Assembly Part Number             : 800-29536-03
Top Assembly Serial Number           : FTX144390KE
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1252AG-A-K9
The name for the keys will be: ap01.u00924.albertsons.com
% The key modulus size is 1024 bits
% Generating 1024 bit RSA keys, keys will be non-exportable...[OK]
Press RETURN to get started!
otCisco Systems, Inc.
*Jun  1 08:25:45.047 MDT: %SNMP-5-COLDSTART: SNMP agent on host ap01 is undergoi
ng a cold start
*Jun  1 08:25:46.083 MDT: %IP_SNMP-3-SOCKET: can't open UDP socket
*Jun  1 08:25:46.083 MDT: Unable to open socket on port 161
*Jun  1 08:25:46.083 MDT: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Jun  1 08:25:46.083 MDT: %LINK-5-CHANGED: Interface Dot11Radio0, changed state
to administratively down
*Jun  1 08:25:47.287 MDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11R
adio0, changed state to down
*Jun  1 08:25:49.267 MDT: %CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED inl
ine power source
*Jun  1 08:25:52.839 MDT: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP a
ddress 192.168.0.143, mask 255.255.255.0, hostname ap01
User Access Verification
Username: resetall
Password:
% Authentication failed
Username:
Username:
Username:
Leo Laohoo
There's a method but it means it will erase your config.  You want that?
Yes please. I do not care about erasing the config. As these units need to be fully tested and restored to factory defaults anyways. They can be reconfigured once they are put back into the field.
Ahhhh ... Music to my ears.
Using a TFTP Server to Return to a Previous Release
I dont get it I get this error whenever trying to download software.
Service Contract RequiredClose
ErrorTo Download this software, you must have a valid service contract associated to your Cisco.com profile.
If you do not have a service contract you can get one through:
  • Your Cisco Account Team if you have a direct purchase agreement with Cisco
  • Your Cisco Partner or Reseller
Once you have the service contract you must associate your service contract to your Cisco.com user ID with Profile Manager
Is there anywhere I can get this software to flash it for free?
