HSRP Configuration help
Sreejesh S
Here I need to configure HSRP in between  two 4948E Coreswitches We have 6 vlans and Intervlan routing enabled on Firewall so please sugest me how can configure HSRP inbetween thos core switch. Please find attached daigram and suggest me Coreswitch commands for HSRP
2 Accepted Solutions
First of all you said that "Intervlan routing enabled on Firewall". What type of  firewall is it? HSRP is cisco proprietary protocol, so it can be used only between cisco devices. If your firewalls are not cisco you have to find out if they support VRRP, which is very similar to HSRP, but it is open standard.
Lower is example configuration of HSRP and VRRP, they are very similar but in some things they work differently (like preempting which VRRP do by default, but in HSRP you have to configure it).
Basically this is configuring default gateway for VLAN 50.
EXAMPLE OF HSRP CONFIGURATION
FirewallA(config)# interface vlan 50
FirewallA(config-if)# ip address 192.168.1.10 255.255.255.0
FirewallA(config-if)# standby 1 priority 200
FirewallA(config-if)# standby 1 preempt
FirewallA(config-if)# standby 1 ip 192.168.1.1
FirewallA(config-if)# standby 1 authentication MyKey
FirewallB(config)# interface vlan 50
FirewallB(config-if)# ip address 192.168.1.11 255.255.255.0
FirewallB(config-if)# standby 1 priority 100
FirewallB(config-if)# standby 1 ip 192.168.1.1
FirewallB(config-if)# standby 1 authentication MyKey
EXAMPLE OF VRRP CONFIGURATION
FirewallA(config-if)# vrrp 1 priority 200
FirewallA(config-if)# vrrp 1 ip 192.168.1.1
FirewallB(config-if)# vrrp 1 priority 100
FirewallB(config-if)# no vrrp 1 preempt
FirewallB(config-if)# vrrp 1 ip 192.168.1.1
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
IP addressing looks good, but I do not get why did you configure same priority for both switches. You should prefer one switch over another, or maybe you can configure "load-balancing" -> half of vlans will be go over one switch and another half over other switch.
Also, I see no point of tracking interface Gigaethernet1/0/2 on both firewalls, both firewalls will send HSRP hellos via these interfaces (directly connected) so if interface or link fail, no hellos will be received and HSRP peer will be presumed dead.
You should rather track your uplink interfaces to internet, because there is no point to be a gateway for LAN if you do not have working uplink to internet.
Or you should configure IP SLA and track state of IP SLA [monitoring gateway] because sometimes uplink port is up/up but link is not working properly.
Best Regards
11 Replies 11
Gregory Snipes
Level 4
Level 4
If you have the inter-VLAN routing setup on the firewalls and not the switches then you cannot configure HSRP on the switches. You must use whatever the firewalls support (probably active/standby failover) for high availability.
As Gregory pointed, HSRP/VRRP has to be run between devices acting as default gateways.
Best Regards
Could you please suggest me how can configure failover/hsrp based on this daigram and please give sample configuration also
Best Regards
Switch>enable
Switch#configure terminal
Switch(config)#hostname Coreswitch1
Coreswitch1(config)#enable secret Cisco
Coreswitch1(config)#banner motd #Welcome Authorized Users Unauthorized access prohibited!#
Coreswitch1(config)#line vty 0 4
Coreswitch1(config-line)#password cisco123
Coreswitch1(config-line)#login
Coreswitch1(config)#line console 0
Coreswitch1(config)#vlan 10
Coreswitch1(config-vlan)#name data
Coreswitch1(config)#vlan 20
Coreswitch1(config-vlan)#name Mgt
Coreswitch1(config)#vlan 30
Coreswitch1(config-vlan)#name LIOM
Coreswitch1(config)#vlan 40
Coreswitch1(config-vlan)#name IPCam
Coreswitch1(config)#vlan 50
Coreswitch1(config-vlan)#name BUR
Coreswitch1(config)#vlan 60
Coreswitch1(config-vlan)#name Heartbeats
Coreswitch1(config)#interface range fastEthernet 1/0/4– 20
Coreswitch1(config-if)#description to Dell Server
Coreswitch1(config-if-range)#switchport mode access
Coreswitch1(config-if-range)#switchport access vlan 10
Coreswitch1(config-if-range)#No Shutdown
Coreswitch1(config)#interface range fastEthernet 1/0/21-25
Coreswitch1(config-if)#description to Mangnt port
Coreswitch1(config-if-range)#switchport access vlan 20
Coreswitch1(config)#interface Gigaethernet1/0/1
Coreswitch1(config-if)#description to Firewall
Coreswitch1(config-if)#switchport mode trunk
Coreswitch1(config-if)#switchport trunk encapsulation dot1q
Coreswitch1(config-if)#switchport trunk allowed vlan all
Coreswitch1(config)#interface Gigaethernet1/0/2
Coreswitch1(config-if)#description to Coreswitch2
Coreswitch1(config)#interface Gigaethernet1/0/3
Coreswitch1(config-if)#description to Access Switch
Coreswitch1(config)#interface port-channel 1
Coreswitch1(config-if)#no ip address
Coreswitch1(config-if)#logging event link-status
Coreswitch1(config-if)#switchport access vlan 10
Coreswitch1(config)#interface  range fastEthernet 1/0/4 – 20
Coreswitch1(config-if)#channel-group 1 mode active
Coreswitch1(config)#spanning-tree mode rapid-pvst
Coreswitch1(config)#spanning-tree loopguard default
Coreswitch1(config)#no spanning-tree optimize bpdu transmission
Coreswitch1(config)#spanning-tree extend system-id
Coreswitch1(config)#spanning-tree pathcost method long
Coreswitch1(config)#interface Vlan10
Coreswitch1(config-if)#no IP
Coreswitch1(config-if)#standby 1 ip 172.16.1.254
Coreswitch1(config-if)#standby 1 priority 102
Coreswitch1(config-if)#standby 1 preempt
Coreswitch1(config-if)#standby 1 timers 1 4
Coreswitch1(config-if)#standby 1  track Gigaethernet1/0/2
Coreswitch1(config)#interface Vlan20
Coreswitch1(config-if)#standby 1 ip 172.16.2.30
Coreswitch1(config-if)#standby 1 priority 103
Coreswitch1(config)#interface Vlan30
Coreswitch1(config-if)#standby 1 ip 172.16.2.62
Coreswitch1(config-if)#standby 1 priority 104
Coreswitch1(config)#interface Vlan40
Coreswitch1(config-if)#standby 1 ip 172.16.2.94
Coreswitch1(config-if)#standby 1 priority 105
Coreswitch1(config)#interface Vlan50
Coreswitch1(config-if)#standby 1 ip 172.16.2.110
Coreswitch1(config-if)#standby 1 priority 106
Coreswitch1(config)#interface Vlan60
Coreswitch1(config-if)#standby 1 ip 172.16.2.126
Coreswitch1(config-if)#standby 1 priority 107
please check this configuration and suggest me if have any corrections
thanks
Sreejesh S
Hello Sreejesh,
First of all, you have to configure IP addresses on Vlan interfaces, if you do not do that, HSRP will not work.
Second, we need to see configuration of second switch where HSRP will be enabled and how both switches will be connected together.
Best Regards
thanks for your inputs
please find bot switch configuration
Cisco 4900 Core switch  1
Switch>enable
Coreswitch1(config-if)#Ip address 172.16.1.253 255.255.255.0
Coreswitch1(config-if)# Ip address 172.16.2.29 255.255.255.224
Coreswitch1(config-if)# Ip address 172.16.2.61 255.255.255.224
Coreswitch1(config-if)# Ip address 172.16.2.93 255.255.255.224
Coreswitch1(config-if)# Ip address 172.16.2.109 255.255.255.224
Coreswitch1(config-if)# Ip address 172.16.2.125 255.255.255.224
Coreswitch1(config)#ip route 0.0.0.0 0.0.0.0 172.16.1.1
Coreswitch1(config)#vtp mode server
Coreswitch1(config)#vtp domain KP
Coreswitch1(config)#vtp password Cisco
Cisco 4900 Core switch2
Switch>enable
Switch(config)#hostname Coreswitch2
Coreswitch2(config)#enable secret Cisco
Coreswitch2(config)#banner motd #Welcome Authorized Users Unauthorized access prohibited!#
Coreswitch2(config)#line vty 0 4
Coreswitch2(config-line)#password cisco123
Coreswitch2(config-line)#login
Coreswitch2(config)#line console 0
Coreswitch2(config)#vlan 10
Coreswitch2(config-vlan)#name data
Coreswitch2(config)#vlan 20
Coreswitch2(config-vlan)#name Mgt
Coreswitch2(config)#vlan 30
Coreswitch2(config-vlan)#name LIOM
Coreswitch2(config)#vlan 40
Coreswitch2(config-vlan)#name IPCam
Coreswitch2(config)#vlan 50
Coreswitch2(config-vlan)#name BUR
Coreswitch2(config)#vlan 60
Coreswitch2(config-vlan)#name Heartbeats
Coreswitch2(config)#interface range fastEthernet 1/0/4– 20
Coreswitch2(config-if)#description to Dell Server
Coreswitch2(config-if-range)#switchport mode access
Coreswitch2(config-if-range)#switchport access vlan 10
Coreswitch2(config-if-range)#No Shutdown
Coreswitch2(config)#interface range fastEthernet 1/0/21-25
Coreswitch2(config-if)#description to Mangnt port
Coreswitch2(config-if-range)#switchport access vlan 20
Coreswitch2(config)#interface Gigaethernet1/0/1
Coreswitch2(config-if)#description to Firewall
Coreswitch2(config-if)#switchport mode trunk
Coreswitch2(config-if)#switchport trunk encapsulation dot1q
Coreswitch2(config-if)#switchport trunk allowed vlan all
Coreswitch2(config)#interface Gigaethernet1/0/2
Coreswitch2(config-if)#description to Coreswitch1
Coreswitch2(config)#interface Gigaethernet1/0/3
Coreswitch2(config-if)#description to Access Switch
Coreswitch2(config)#interface port-channel 1
Coreswitch2(config-if)#no ip address
Coreswitch2(config-if)#logging event link-status
Coreswitch2(config-if)#switchport access vlan 10
Coreswitch2(config)#interface  range fastEthernet 1/0/4 – 20
Coreswitch2(config-if)#channel-group 1 mode active
Coreswitch2(config)#spanning-tree mode rapid-pvst
Coreswitch2(config)#spanning-tree loopguard default
Coreswitch2(config)#no spanning-tree optimize bpdu transmission
Coreswitch2(config)#spanning-tree extend system-id
Coreswitch2(config)#spanning-tree pathcost method long
Coreswitch2(config)#interface Vlan10
Coreswitch2(config-if)#Ip address 172.16.1.252 255.255.255.0
Coreswitch2(config-if)#standby 1 ip 172.16.1.254
Coreswitch2(config-if)#standby 1 priority 102
Coreswitch2(config-if)#standby 1 preempt
Coreswitch2(config-if)#standby 1 timers 1 4
Coreswitch2(config-if)#standby 1  track Gigaethernet1/0/2
Coreswitch2(config)#interface Vlan20
Coreswitch2(config-if)# Ip address 172.16.2.28 255.255.255.224
Coreswitch2(config-if)#standby 1 ip 172.16.2.30
Coreswitch2(config-if)#standby 1 priority 103
Coreswitch2(config)#interface Vlan30
Coreswitch2(config-if)# Ip address 172.16.2.60 255.255.255.224
Coreswitch2(config-if)#standby 1 ip 172.16.2.62
Coreswitch2(config-if)#standby 1 priority 104
Coreswitch2(config)#interface Vlan40
Coreswitch2(config-if)# Ip address 172.16.2.92 255.255.255.224
Coreswitch2(config-if)#standby 1 ip 172.16.2.94
Coreswitch2(config-if)#standby 1 priority 105
Coreswitch2(config)#interface Vlan50
Coreswitch2(config-if)# Ip address 172.16.2.108 255.255.255.224
Coreswitch2(config-if)#standby 1 ip 172.16.2.110
Coreswitch2(config-if)#standby 1 priority 106
Coreswitch2(config)#interface Vlan60
Coreswitch2(config-if)# Ip address 172.16.2.124 255.255.255.224
Coreswitch2(config-if)#standby 1 ip 172.16.2.126
Coreswitch2(config-if)#standby 1 priority 107
Coreswitch2(config)#ip route 0.0.0.0 0.0.0.0 172.16.1.1
Coreswitch2(config)#vtp mode server
Coreswitch2(config)#vtp domain KP
Coreswitch2(config)#vtp password Cisco
both switch connected through Ge1/0/2
Best Regards
1).regarding that priority its my mistake while configure it should be different because I am looking for Active/Standby mode
2).then could you please advice me how can configure IP SLA for G1/0/2 which one connected inbetween HSRP switches
3.) And need to configure  internet uplink which one conneted to G1/0/1 in both switch
thanks
Sreejesh
ip sla 1
icmp-echo IP_ADDRESS_GW
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 state
interface VlanXYZ
standby 1 track 1 decrement 50
You will track some IP [IP_ADDRESS_GW] which is only accessible via local uplink interface. IP SLA and TRACKing allow you to manipulate some parameters, delay, threshold, timeout so maybe you will play with these to tune failover.
If tracked IP will not be accessible, tracking state will change to DOWN, and standby priority will decrement by 50.
I can not help you with this, cause I do not know any details about your connection/ISP/IP addresses/where do you connect G1/0/1 port/etc...
Best Regards
Your diagram indicated these are checkpoint firewalls. I have no idea how those work but a quick Google search revealed this aministration guide. You would need to look under the failover section for information on how to do what you are looking for.
