HSRP configuration - possible routing loop
ohareka70
Level 3
Level 3
  • W is my primary site
  • B is my DR site
Could someone check this one for me please?
ip route 10.0.0.0 255.0.0.0 192.168.180.1 track 11                                                   site B
ip route 10.0.0.0 255.0.0.0 192.168.180.199 255 track 12                                        site B
ip route 10.0.0.0 255.0.0.0 192.168.180.1 track 11                                                   site W
ip route 10.0.0.0 255.0.0.0 192.168.180.199 255 track 12                                        site W
I was told to configure them both the same like this on both routers to avoid a loop in my network
But they then both go out via the same firewall interface of 192.168.180.1
Is this correct?
Should the B site not be like this so it goes out via the other firewall
ip route 10.0.0.0 255.0.0.0 192.168.180.1 255 track 11                                             site B
ip route 10.0.0.0 255.0.0.0 192.168.180.199 track 12                                                site B
thanks
Reza Sharifi
If the firewalls are configured as active/stand-by than the first config is correct. The traffic will always traverse the primary until there is failure.
Reza Sharifi
Reza, The firewalls are configured as active/active.  Both are passing traffic to the internet
thanks
Kevin
I looked at the drawing and couldn't figure out where 10.0.0.0/8 terminates and also routers that have HSRP configured which location they are at? Is this a lab environment or real network?
As far as static routes are concerned both routes will be installed in the RIB because I didn't notice user configured AD tied to the static routes.
Please let me know if I missed anything.
Got it working
B-side (i changed the default route)
ip route 0.0.0.0 0.0.0.0 192.168.180.1 250 track 1
ip route 0.0.0.0 0.0.0.0 192.168.180.199 track 2
thanks for your help
