07-02-2016 12:12 AM - edited 03-08-2019 06:28 AM
Does the standby group number need to be the same on both the primary and backup routers for it to work properly?
Thank you in advance for your help!
Solved! Go to Solution.
07-02-2016 02:58 AM
you can configure more than one HSRP group on an interface ("MHSRP") but only matching groups will form Active/Standby-pairs among routers. The Group ID will be part of the virtual MAC address of the Active router and host on the segement use this vMAC to encapsulate traffic sent to their default-gateway.
Rolf
07-06-2016 01:25 AM
The timers do not necessarily have to match but it is highly recommended to keep such parameters consistent.
07-02-2016 02:58 AM
Rolf
07-03-2016 04:03 AM
Good to know that. Thank you.
07-05-2016 10:47 PM
Aside from the group numbers that should match on both routers, should other parameters like timers should match as well for HSRP to work properly?
07-06-2016 01:25 AM
