HSRP issue with L3 switches
sidris-sid
Hi ,
I’m facing strange issue with HSRP, I configure HSRP between two Core switches “3750 =Core 1 & 3560 =Core 2” I tried to load sharing between the two switches, for instance VLAN9 be active in Core1 & standby in core 2 other VLan active in Core 2 standby Core1 ….the issue that I’m facing is when I ping server within VLAN 9 is pinging only if VLAN 9 is active within Core2 even if the server is directly connected to Core 1 …..Already there is trunk between the two switches “Etherchannel”
Here is my Config:
Core1:
interface Vlan9
ip address 192.168.9.252 255.255.255.0
standby 1 ip 192.168.9.254
standby 1 preempt
standby 1 priority 95
standby 1 track GigabitEthernet1/0/33
standby 1 track GigabitEthernet1/0/34
Core2:
interface Vlan9
interface Vlan9
ip address 192.168.9.253 255.255.255.0
standby 1 preempt
standby 1 track GigabitEthernet0/33
standby 1 track GigabitEthernet0/34
tj.mitchell
Level 4
Level 4
According to your configuration for VLAN 9, Core-2 will be the primary and Core-1 will be in standby. The default priority for HSRP is 100 and the higher the priority takes over. So, putting the priority at 95 on Core-1 and leaving the default priority on Core-2 will cause Core-2 to answer your requests.
Change the priority on Core-1 to something higher than 100 and I think you'll see what you are looking for.
glen.grant
   If you have a trunk link between those 2 switches you should be able to ping it . If not my guess would be the server default gateway is not pointed to the HSRP virtual address  (192.168.9.254) as the gateway.
