HSRP issue
Anuj Singhi
Level 3
Level 3
I have a server in location A and other server in location B. There is HSRP setup from vlan 11 in location A. When I try to ping a server in location B without any source its working fine, but if i ping the same source from active switch of location A keeping vlan 11 as source I am not able to ping. Please help
Hello Sounds like routing issue and location B hasn't a route back to vlan 11 is vlan 11 being advertised and is location B seeing this prefix? Res Paul
Kind Regards
Paul
Anuj, try to trace route from B location and as mentioned above, check routing /access lists on the device where trace stops..
