HSRP loadbalacing
naitikpatel
Whichy type of method available for loadbalancing in HSRP can you brife those mothode with example.
cadet alain
You must use mHSRP to do "load-balancing"
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094e90.shtml
If you need help about the config don't hesitate to ask.
Alain
Most implementations that I have seen in datacenter and enterprise networks are as follows.
Router-A will have 10 HSRP Standby Groups as the Active Router, and Router-B will have 10 HSRP Standby Groups as the Active Router. Obviously each others router will be the Standby.
Now, 10 is just a number I picked.
I'll let Cadet throw down the config
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Alain and John have described, you can load balance, for the same subnet, if mHSRP is supported.  For different subnets, you can alternate which router hosts the active gateway, i.e. mHSRP isn't required.  The former also requires you somehow have hosts use the different mHSRP IPs, which is a pain.  If you're equipment supports GLBP, you might find that a "better" solution.
