HSRP on Layer 3 switch (cisco 3560)
ssweehinlew
To implement the HSRP on 2 different networks and connect them to each others (for example network A and network B) with cisco switch 3560, how many switches are required?
Network A = 2 switches
Network B = 2 switches
or
Network A = 1 switch
Network B = 1 switch
Your help is much appreciated. Thanks.
Jon Marshall
or
To implement HSRP you would need at least 2 switches per subnet for it to make any sense. But you could use the same 2 switches for both network A and network B.
Jon
Ganesh Hariharan
or
To implement HSRP you will need at least two switches and for running HSRP in two different subnet you can also achive with the same two switches by creating vlans and apply HSRP to those vlans.
Hope to help
If helpful do rate the post
Ganesh.H
