HSRP on trunk
lformelli
can I configure HSRP from two router with only one inteface ethernet for each so that I have to use trunk 802.1q (Vlan) ?
Does anyone advice me one a document about ?
Best regards
Lorenzo
arturo.guzman
You can configure hsrp per vlan, using and instances of the stand by like this.
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.6.1.252 255.255.255.0
no ip redirects
ip nbar protocol-discovery
ip policy route-map internet-corp
standby use-bia scope interface
standby 51 ip 10.6.1.254
standby 51 priority 210
standby 51 preempt
standby 51 track Serial0/0.18 150
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.6.2.252 255.255.255.0
no ip redirects
standby 52 ip 10.6.2.254
standby 52 priority 110
standby 52 preempt
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 10.6.3.252 255.255.255.0
no ip redirects
standby 53 ip 10.6.3.254
standby 53 priority 210
standby 53 preempt
standby 53 track Serial0/0.18 150
don't forget qualify me.
correct example
just a little explanation you need to use different HSRP group number on the vlan subintefaces. This derives from the Cisco implementation on Cisco routers that don't retain the vlan tag to decide to what HSRP instance a received HSRP packet belongs.
Using the same group address will produce an error message.
hope to help
Giuseppe
I just wanted to explain why we need to use different group numbers the example is correct.
best regards
Giuseppe
lformelli
Hi Giuseppe,
I want show you the configuration of my two
routers HSRP with trunk for Vlans.
Can it work in order ?
best regards
Lorenzo
Cisco 1800
no ip address
duplex auto
speed auto
ip address 192.168.19.253 255.255.255.0
standby 1 ip 192.168.19.254
standby 1 priority 105
standby 1 preempt
standby 1 track serial0/0
ip address 172.16.19.3 255.255.255.0
standby 2 ip 172.16.19.1
standby 2 priority 100
standby 2 preempt
standby 2 track serial0/0
Cisco 2600
no ip address
duplex auto
speed auto
ip address 192.168.19.252 255.255.255.0
standby 1 priority 100
standby 1 preempt
ip address 172.16.19.4 255.255.255.0
standby 2 priority 105
standby 2 preempt
