HSRP possible issue need help
NetriverNOC
When use the command
sh standby internal
at the bottom there is a table that seems to have an overlapping number in the HSRP column? "116"
Can anyone tell me what that value is for and if it is an issue?
chinkevi_2
i believe the group number on an interface is the same as group number on another interface?
if so, they don't have to be unique across all interfaces. They only have to be unique per interface. i.e. all interfaces can have standby group 1. This is due to you don't expect to see the same hsrp multicast on different interfaces.
all the group numbers ar unique? you can double check me on the attachment but that was the first thing I looked at.
