HSRP question
OPS_account
can we run HSRP on two interfaces on the same router ??
ex: i have to ether interfaces
Ether1 Ether2
IP 10.1.1.1 10.1.1.2
standby 10.1.1.3 10.1.1.3
Jon Marshall
No i don't believe you will be able to do this as you cannot assign 2 ethernet interfaces on the same router to the same subnet. When you come to configure the 2nd ethernet connection you will get an error saying the address overlaps with ether1.
Jon
NO, you cannot configure the same subnet on the a same router, because it overlaps & you a message too when you try that.
