HSRP Questions
Ammit
Hi guys
  I have a design where I have three layer 2 switches connected to a layer 3 switch. The layer 2 switches each have vlans (10,20,30) and I can communicate across vlans fine. I am trying to add redundancy to the design by adding a standby layer 3 switch.
This is the current configuration of the primary layer 3 thus far:
Building configuration...
Current configuration : 1626 bytes
version 12.2(37)SE1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname CORE/DIST-SW
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
 switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 description IT
 mac-address 0001.c998.1b01
 ip address 10.0.1.1 255.255.255.0
interface Vlan20
 description HR
 mac-address 0001.c998.1b02
 ip address 10.0.2.1 255.255.255.0
interface Vlan30
 description HR
 mac-address 0001.c998.1b03
 ip address 10.0.3.1 255.255.255.0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
 login
end
The problem is when I go into the layer 3 switch and set up tracking I am unable to add a decrement to Fa0/1, 2, or 3 connection on the layer 3 switch;
CORE/DIST-SW(config)#interface vlan 10
CORE/DIST-SW(config-if)#standby 10 ip 10.0.1.1
%HSRP-6-STATECHANGE: Vlan10 Grp 10 state Speak -> Standby
%HSRP-6-STATECHANGE: Vlan10 Grp 10 state Standby -> Active
CORE/DIST-SW(config-if)#standby 10 priority 110
CORE/DIST-SW(config-if)#standby 10 track fa0/1 ?
<cr>
CORE/DIST-SW(config-if)#standby 10 track fa0/1 20
% Invalid input detected at '^' marker.
Can anyone suggest what is going wrong? Thanks
Mark Malone
i dont think there's anything wrong just the software switch doesn't have that ability
thats a older switch FE it just doesn't have the syntax
xxxxxxxxxxx(config-if)#standby track GigabitEthernet2/8/37 ?
  <1-255>  Decrement value
just set one side as priority 110 and the other as 105
Mark Malone
Thanks for the reply, should I change the switch or just set a priority and dont track?
I wouldn't change the switch , I would just use it without the decrement syntax but you can still use track command
Ah yes thank you now works as planned
