HSRP Taking time to failover
ankitohc
Hi Team,
I just want to know its just a normal behavaiour - Does it 10 seconds to become active?
34 Replies 34
Hmm,
it can but I think it slow.
can I see config of HSRP
MHM
M02@rt37
Hello @ankitohc
In HSRP , the default timers include a 10-second delay before the router with the highest priority becomes the active router. This delay is known as the "Hello Timer" or "Hold Time."
Hello Timer (Hold Time) -- This is the interval at which routers participating in HSRP send hello messages to each other. The default hello time is 3 seconds. If a router does not receive a hello message from the active router within the hold time, it assumes that the active router is no longer available.
Hold Time --The hold time is how long a router considers the HSRP router that sent the last hello message to be the active router. The default hold time is 10 seconds.
So, during the normal operation of HSRP, when a router becomes the active router, it will send hello messages every 3 seconds. If a standby router does not receive a hello message within 10 seconds, it may transition to the active state, assuming that the previously active router is no longer reachable.
If you observe a 10-second delay before a router becomes active in your lab, it aligns with the default HSRP timers. If needed, these timers can be adjusted using the `standby` command on the routers participating in HSRP.
Best regards
Ditto.
I recall (?) HSRPv2 supports subsecond hellos, so usually possible to get a failure switch over in under 2 seconds.  To get subsecond failure switch over I recall you'll usually will want BFD support.
Lots of good HSRP details in https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipapp_fhrp/configuration/xe-3s/fhp-xe-3s-book/fhp-hsrp.html
For example:
You can lower these timer settings to speed up the failover or preemption, but, to avoid increased CPU usage and unnecessary standby state flapping, do not set the hello timer below one second or the hold timer below four seconds.
If the above catches your attention, as it might, when you get into HSRP v1 versus V2, and BFD usage, you'll better understand HSRP, very useful if you want to reduce its default failure switch over time.
ankitohc
also, getting duplicate error
SW1-
SW1#show run
SW1#show running-config
Building configuration...
Current configuration : 1017 bytes
! Last configuration change at 20:20:56 UTC Wed Dec 20 2023
version 15.2
service compress-config
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool 1
network 10.10.1.0 255.255.255.0
dns-server 8.8.8.8
default-router 10.10.1.3
ip cef
no ipv6 cef
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Ethernet0/0
interface Ethernet0/1
switchport mode trunk
interface Ethernet0/2
interface Ethernet0/3
interface Vlan1
ip address 10.10.1.1 255.255.255.0
standby version 2
standby 0 ip 10.10.1.3
standby 10 priority 70
standby 11 priority 80
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
*Dec 20 20:54:08.942: %IP-4-DUPADDR: Duplicate address 10.10.1.3 on Vlan1, sourced by 0000.0c9f.f00a
interface Vlan1
standby version 2
standby 10 priority 70 <- no need
standby 11 priority 80 <- no need
You config priority to group not use' you need
Standby 0 priority (make it different to elect the active hsrp)
Config root primary  in active hsrp l3sw
Config root secondary in standby l3sw hsrp
Config hsrp preempt in both l3sw
Wr config
Turn off then turn on
After that check recover time
MHM
Hello
The defaults are hello/hld timers are 3/10 seconds respectively  so what you see is valid, if you wish to decrease thses timer then you can do so:
Example
standby 10 timers msec 250 msec 800
sh standby | be Group 10
Kind Regards
Paul
ankitohc
SW2>EN
SW2#SHOW RUN
SW2#SHOW RUNning-config
Current configuration : 835 bytes
! Last configuration change at 20:22:35 UTC Wed Dec 20 2023
version 15.2
hostname SW2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
interface Vlan1
ip address 10.10.1.2 255.255.255.0
standby version 2
standby 10 ip 10.10.1.3
standby 10 priority 99
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
SW2#
SW2#
*Dec 20 20:56:37.626: %IP-4-DUPADDR: Duplicate address 10.10.1.3 on Vlan1, sourced by 0000.0c9f.f000
SW2#
SW2#
SW2#
*Dec 20 20:57:08.626: %IP-4-DUPADDR: Duplicate address 10.10.1.3 on Vlan1, sourced by 0000.0c9f.f000
In l3sw two the hsrp group is wrong you need to use same hsrp group in both l3sw hsrp
MHM
@MHM Cisco World
I have corrected the confguration now its reduced however its still 5 seconds
Reduce and there is no duplicate?
If Yes we are in right way
Now can you share last config let me make double check.
MHM
Duplicate error is gone.. let me share your latest config
SW1#wr
Compressed configuration from 969 bytes to 658 bytes[OK]
SW1#
*Dec 20 21:58:05.038: %SYS-5-CONFIG_I: Configured from console by console
SW1#
SW1#show run
Current configuration : 969 bytes
! Last configuration change at 21:58:05 UTC Wed Dec 20 2023
version 15.2
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool 1
dns-server 8.8.8.8
ip cef
no ipv6 cef
interface Vlan1
standby version 2
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
ankitohc
SW2#show run
SW2#show running-config
Current configuration : 810 bytes
! Last configuration change at 21:56:10 UTC Wed Dec 20 2023
version 15.2
hostname SW2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
interface Vlan1
standby version 2
no ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
You dont config spanning root primary in active
And spanning root secondary in standby
Do this make sure stp root is active l3sw hsrp.
MHM
