communicate between two vlan
lynbuehler
Community Member
How do I make the vlan 100 on the interface 0/0 on the router forward to the 200 vlan on the interface 0/1 of the router and vice versa?
M02@rt37
Hello @lynbuehler
Since you have configured Fa 0/0 and 0/1 as sub interfaces with the vlan tag, routing between vlan should be ok !
int fa 0/0
no shut
int fa 0/0.100
encapsulation dot1q 100
ip address x.x.x.x. mask
no shut
int fa 0/1
no shut
int fa 0/1.200
encapsulation dot1q 200
ip address x.x.x.x mask
no shut
Best regards
balaji.bandi
how is your configuration looks like on the router - show run help here.
if they are configured already VLAN 100 and VLAN 200 on Router - IP routing help you to route the traffic.
If i understand correctly you looking VLAN 100 and VLAN 200 network should able to communicate each other. (post show run)
BB
Blue_Bird
Hello lynbuehler,
Make sure on Fa0/0 and Fa0/1 you have given no shutdown.....according to diagram...it seems you have given.
You will be needed to configure sub-interface on each physical interface...
Int fa0/0.1
ip address x.x.x.x sunetmask
int fa0/1.1
ip address x.x.x.x sumnetmask
All PC's make sure you have given correct ip address, subnetmask and Default Gateway
You can use the link for reference: https://networklessons.com/switching/intervlan-routing
I hope the above the information is useful....still if you have issues...Please share the configuration...
Best regards
******* If This Helps, Please Rate *******
