HSRP timers
Patrick McHenry
Level 4
Level 4
I always thought that setting the hello and hold timers to different values on HSRP partners would not allow it to work or atleast not allow preemtion to wor. It seems to work fine in lab. Am I missing something?
Thanks, Pat.
16 Replies 16
andtoth
Level 4
Level 4
Hi Patrick,
You can configure the HSRP timers, that's not an issue, even preemption will work.
Routers or access servers on which standby timer values are not configured can learn timer values from the active or standby router. The timers configured on an active router always override any other timer settings.
HSRP Timers
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml#topic14
Configuring HSRP Authentication and Timers
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_55_se/configuration/guide/swhsrp.html#wp1044417
Best regards,
Andras
But I had one switch set as hello 3 hold 10 and the other hello msec 500 hold msec 1500 and it still worked. Are you saying that it only matters what the active router's timers are?
Andras
So, it doesn't matter that the timers are set differently on the HSRP partners but, like Amit said, it is not recommended?
Andras,
I have got a ques for you. So, whatever we configure on standby router, if we do "show standby", should we see the same timers in the o/p on both active & standby?
Amit
In my lab I didn't. One routersaid 3 10 and the other was msec 500 msec 1500
That might depend on the platform and software version and could be just cosmetic.
Andras
Sorry to bump into this old thread...
you're probably running HSRPv1 and there is a subtle difference when talking about timers:
In HSRP version 1, millisecond timer values are not advertised or learned.
So yes, timers are advertised or learned in HSRPv1 unless you've configured msec timers.
Very confusing and I'm guessing this would/could cause unpredictable situations...
Jeroen
Hi Amit,
You will see the same timer values on both the standby and active, those are advertised by the active.
The following is from a standby hsrp device which is a 6500:
#sh run int vlan777
interface Vlan777
ip address 192.168.43.7 255.255.255.0
standby 77 ip 192.168.43.3
standby 77 priority 50
standby 77 preempt
end
#sh standby vlan777
Vlan777 - Group 77
  Local state is Standby, priority 50, may preempt
  Hellotime 1 sec, holdtime 3 sec
  Next hello sent in 0.018
  Virtual IP address is 192.168.43.3 configured
  Active router is 192.168.43.2, priority 150 expires in 2.252
  Standby router is local
  1 state changes, last state change 00:00:35
  IP redundancy name is "hsrp-Vl777-77" (default)
As you can see, timers are not configured on the standby device, although they are set to hello 1 and hold 3 because it's set on the active.
If you configure it on the standby only, you will see the following:
#sh stand vlan777
Vlan777 - Group 77
  Hellotime 3 sec (cfgd 1 sec), holdtime 10 sec (cfgd 5 sec)
  Next hello sent in 1.125
  Active router is 192.168.43.2, priority 150 expires in 8.652
  1 state changes, last state change 00:04:53
Best regards,
Andras
Message was edited by: Andras Toth
Thanks Andras, I got it. I checked it & it does change.
My lab did not work like this. I guess I will try it again. So, you are showing me that what ever I set the active timers to, the standby with take on the same values?
Thanks, Pat
I'm using 3750s with ip base software
Hi Pat,
Yes your understanding is correct. The standby should learn and use the timer values advertised by the active hsrp device.
Which specific version do you run on the 3750 ?
Andras
c3750-ipbasek9-mz.122-55.SE1.bin
Hi Patrick,
I have tested it on a 3750 running 12.2(55)SE3 and the standby shows the actual timers, advertised by the active device.
When configured on the active and left at default on standby, instead of the default 3 and 10, it shows the configured 1 and 5.
#sh stand vl2
Vlan2 - Group 2
  State is Standby
    1 state change, last state change 00:01:27
  Virtual IP address is 167.167.167.254
  Active virtual MAC address is 0000.0c07.ac02
    Local virtual MAC address is 0000.0c07.ac02 (v1 default)
  Hello time 1 sec, hold time 5 sec
    Next hello sent in 0.432 secs
  Preemption disabled
  Active router is 167.167.167.1, priority 150 (expires in 4.768 sec)
  Priority 100 (default 100)
  Group name is "hsrp-Vl2-2" (default)
When configured on standby as well:
#sh stand vl2
Vlan2 - Group 2
  State is Standby
    1 state change, last state change 00:03:33
  Hello time 1 sec (cfgd 2 sec), hold time 5 sec (cfgd 6 sec)
    Next hello sent in 0.640 secs
  Preemption disabled
  Active router is 167.167.167.1, priority 150 (expires in 5.072 sec)
Best regards,
Andras
