HSRP with Catalyst & Checkpoint Cluster
subra4u
Hi All,
We are planning for redundancy at Layer 3 and hence we have decided to go with HSRP between Cat 3750 switches. The bottle neck is we are implementing Checkpoint Clustering as well and I would like to know, if anyone tried this using HSRP/SVI and Cluster XL i.e. will both work on virtual IP for intercommunication or is there any other way to achieve this.
Have a look at the rough sketch attached any ideas appreciated.
Thanks In advance,
bjornarsb
Level 4
Level 4
We have just the same setup and I would be glad to share it with you :)
It works perfect.
To be honest I do not want to post it on Netpro, but send me an e-mail and I will give you configurations (without confidential info)
BR,
Bjornarsb
Thanks for your quick,response. Can I have your email address please.
Thanks in Advance,
sorry about the delay :) To much working.
my e-mail is: bjornar.bjorge@norgesgruppen.no
BR,
Bjornarsb
