HSRP with multiple secondary IP addresses
dhananjay95929
I have two routers running in active/standby mode for VPN connectivity to customers. They are configured for HSRP using their two primary IP addresses on each router's interface. The primary HSRP is working as expected without issues.
How do I configure the routers for HSRP with multiple secondary IP addresses and HSRP for each secondary IP address? I have tried using the secondary keyword in the “standby [group-number] ip [ip-address] secondary” statement, however, the problem is all IP addresses (primary and secondarys) are in the same /24 subnet.  I am faced with the following problem then:
  • •1.      How would the HSRP process for a secondary standby IP address know what physical secondary standby IP address to switch to in case of a failover?
  • •2.      If I use a different standby group number for each secondary standby IP address that I create how can I link the secondary IP addresses on the physical interfaces to that specifc standby group number for segregation?
Here are the router configs for the desired HSRP and stateful failover sections,it does not work, the “show standby brief” command shows the 2, 3 and 4 secondary HSRP group numbers in the INIT states and unknown under every other column.
Router 1:
interface FastEthernet0/0
ip address 192.168.1.131 255.255.255.0 secondary
ip address 192.168.1.134 255.255.255.0 secondary
ip address 192.168.1.137 255.255.255.0 secondary
ip address 192.168.1.151 255.255.255.0
standby delay minimum 30 reload 60
standby 1 ip 192.168.1.150
standby 1 timers 1 5
standby 1 name vpnout
standby 1 track FastEthernet3/0
standby 2 ip 192.168.1.130 secondary
standby 2 timers 1 5
standby 2 track FastEthernet3/0
standby 3 ip 192.168.1.133 secondary
standby 3 timers 1 5
standby 3 track FastEthernet3/0
standby 4 ip 192.168.1.136 secondary
standby 4 timers 1 5
standby 4 track FastEthernet3/0
crypto map vpnmap redundancy vpnout stateful
crypto map vpnmap redundancy replay-interval inbound 10 outbound 1000
Router 2:
ip address 192.168.1.132 255.255.255.0 secondary
ip address 192.168.1.135 255.255.255.0 secondary
ip address 192.168.1.138 255.255.255.0 secondary
ip address 192.168.1.152 255.255.255.0
Thanks in advance for any insight you can provide.
dhananjay95929
The following is shown under "show standby" and "show standby brief" commands for Group 2:
FastEthernet0/0 - Group 2
State is Init
Virtual IP address is unknown
Secondary virtual IP address 192.168.1.130
Active virtual MAC address is unknown
Local virtual MAC address is 0000.0c07.ac02 (v1 default)
Hello time 1 sec, hold time 5 sec
Preemption disabled
Active router is unknown
Standby router is unknown
Priority 100 (default 100)
Track interface FastEthernet3/0 state Up decrement 10
Group name is "hsrp-Gi0/0-9" (default)
Interface Grp Pri P    State   Active  Standby Virtual IP
Fa0/0      2  100 Init unknown unknown unknown
Dhananjay,
Its working fine for me.
show standby:
Fa0/0       1    100   Active  local           192.168.1.152   192.168.1.150
Fa0/0       3    100   Init    unknown         unknown         unknown
Fa0/0       4    100   Init    unknown         unknown         unknown
R1#sh standby
FastEthernet0/0 - Group 1
  State is Active
    2 state changes, last state change 00:01:20
  Virtual IP address is 192.168.1.150
  Active virtual MAC address is 0000.0c07.ac01
    Local virtual MAC address is 0000.0c07.ac01 (v1 default)
    Next hello sent in 0.616 secs
  Preemption disabled
  Active router is local
  Standby router is 192.168.1.152, priority 100 (expires in 4.188 sec)
  Group name is "vpnout" (cfgd)
  State is Init
  Preemption disabled
  Group name is "hsrp-Fa0/0-2" (default)
FastEthernet0/0 - Group 3
  State is Init
    Secondary virtual IP address 192.168.1.133
    Local virtual MAC address is 0000.0c07.ac03 (v1 default)
  Preemption disabled
  Group name is "hsrp-Fa0/0-3" (default)
FastEthernet0/0 - Group 4
  State is Init
    Secondary virtual IP address 192.168.1.136
    Local virtual MAC address is 0000.0c07.ac04 (v1 default)
  Preemption disabled
  Group name is "hsrp-Fa0/0-4" (default)
R1#
Inayath
Do you know why the output shows as "unknown" under the Active, Standby and Virtual IP columns and State as "init" ?
Thanks!
I [think] that I figured this out finally. If any one has any thoughts or objections please respond.
There are two ways this can be achieved.
1. Create a secondary standby IP address in the same standby group as the primary standby IP address using the "standby [Primary Grp Num] ip [A.B.C.D] secondary" command.
OR
2. Create a new standby group and specify a standby IP address without the secondary keyword.
There is no need for two additional secondary IP addresses on each router's interface as required for the primary. You can just specify the "standby ip [A.B.C.D] secondary" command where A.B.C.D = secondary standby IP address and let the HSRP process use the interface's primary IP addresses for determining the active and standby routers.
You may configure like this:
For Case 1:
Router 1:
ip address 192.168.1.131 255.255.255.0 secondary [can exclude this statement]
ip address 192.168.1.134 255.255.255.0 secondary [can exclude this statement]
ip address 192.168.1.137 255.255.255.0 secondary [can exclude this statement]
standby 1 ip 192.168.1.130 secondary
standby 1 ip 192.168.1.133 secondary
standby 1 ip 192.168.1.136 secondary
Router 2:
ip address 192.168.1.132 255.255.255.0 secondary [can exclude this statement]
ip address 192.168.1.135 255.255.255.0 secondary [can exclude this statement]
ip address 192.168.1.138 255.255.255.0 secondary [can exclude this statement]
For Case 2:
Router 1:
Router 2:
