Hub didnt disable with bpduguard enable
ohareka70
Level 3
Level 3
I have the following configuration on my access layer switch.
interface FastEthernet0/1 - 20
switchport access vlan 4
switchport mode access
spanning-tree portfast
spanning-tree bpduguard enable
But when i plug in a netgear hub into one of the user ports it didnt err-disable the port.
I need this to stop users plugging in a hub onto our network so they have extra access ports.
Any ideas why the bpduguard did not work.
thanks
Kevin
Abzal
Level 7
Level 7
For this situation you can use
#switchport port-security
#switchport port-security max address 3 (for example)
#switchport port-security mac address sticky
To allow only three PCs to be connected from hub.
Best regards,
Abzal
Abzal
Level 7
Level 7
Best regards,
Abzal
Yeah - port security is a fall back option.
Enabling bpduguard on client facing ports will err-disable the switchport if it receives a bpdu from a connected device. But BPDUs are sent by switches so old hubs won't send bpdus.  For this reason i dont think its possible to err-disable a hub using bpduguard enable
thanks
Kevin
