huge data copy and pasting over 3850
amjadkhan1920
dear all,
i have a real lab which was run before  over utp   ( core switch2960) but for some requirement i install new core switch 3850 and put fiber sfps  now from my server i am copying daily in terabytes after few hours the backup is going fails while reverting to 2960 core switch is working fine any idea please ?
please view my lab in picture the lab1 is working while lab2  is going fails after few hours
Jaderson Pessoa
Hello @amjadkhan1920 ,
Look below, capacity of each switch model.
Jaderson Pessoa
*** Rate All Helpful Responses ***
8 Replies 8
Jaderson Pessoa
Jaderson Pessoa
dear paul,
right now i changed the media from utp to fiber and there is no stp because one to one cable there is no loops but once i revert it to utp and old switches its working please advise me
before it was copper and now fiber and the crc every thing is fine sending and receiving pbdu is ok there is no backup so no concept of stp even no ether channel please advise
hi,
i think this  could be the problem because the forward rate difference between 2960 and 3850
hi,
Hello
I assume the new core is using the same SDM templetes, switching method, stp etc...
Are you using different cabling : copper and now fibre or fibre now copper?
What do the interface statistics report, any drops, errors etc...
Can you post the config of the 2960 and 3850 core?
Kind Regards
Paul
old switch 2960
no aaa new-model
vtp domain ALHOKAIR
vtp mode transparent
ip subnet-zero
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 2
vlan 11
name NW_mgmt
vlan 51,54,172-173,201-203,205,211-214,232-233,235,250,300,400,444,555,666
vlan 778,831,888,999
vlan 1000
name camera
vlan 1018
interface GigabitEthernet0/1
interface GigabitEthernet0/2
description for firewall 203 wan port
spanning-tree portfast
interface GigabitEthernet0/3
description Connected to Cisco_ASA_5520
interface GigabitEthernet0/4
interface GigabitEthernet0/5
description for firewall A 10.20.20.20
switchport mode trunk
interface GigabitEthernet0/6
switchport mode access
interface GigabitEthernet0/7
description for firewall wan port
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
description Connected to Cisco_ASA_5540
interface GigabitEthernet0/14
interface GigabitEthernet0/15
description for fortenet
switchport access vlan 831
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
description shadab pc
switchport access vlan 555
interface GigabitEthernet0/20
interface GigabitEthernet0/21
description connected to GO_Switch
interface GigabitEthernet0/22
interface GigabitEthernet0/23
description ahmad pc
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
description connected to IPVPN Router
interface GigabitEthernet0/27
description connected to IT_Cabinet3
interface GigabitEthernet0/28
description my pc
interface GigabitEthernet0/29
duplex full
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
switchport access vlan 888
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
description mustafa Backup
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
description connected to 1st floor Wless Conf.Room
interface GigabitEthernet0/42
description emad
switchport access vlan 212
interface GigabitEthernet0/43
interface GigabitEthernet0/44
description connected to sw5_2
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
description connected to CORESWITCH Port 5/2
interface GigabitEthernet0/48
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan11
ip address 10.67.0.10 255.255.255.0
no ip route-cache
interface Vlan914
no ip address
no ip route-cache
ip default-gateway 10.67.0.1
ip http server
core 3850
no aaa new-model
switch 1 provision ws-c3850-24xs
coap http enable
qos queue-softmax-multiplier 100
crypto pki trustpoint TP-self-signed-1329356515
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1329356515
revocation-check none
rsakeypair TP-self-signed-1329356515
crypto pki certificate chain TP-self-signed-1329356515
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31333239 33353635 3135301E 170D3139 30313233 31323136
30395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 33323933
35363531 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100AC56 6D13F7C0 A582FCE2 4C928952 6C145FA1 4AE3BB2C B97238B7 561EFE47
3655ADC7 798FAA85 78090571 CAD4C482 B8FA067C 32710C5F CEDAD0B3 CB93978E
82FE7F14 F1C320D3 57360AB9 E96D8E99 A7C391BC 68C913DE 78F2ACCE 8DF5B044
89E99604 8561A721 284C48DF C3C2F506 D63C7D50 61DF1709 74CA38E1 641B99F5
C96D0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1425CE92 83EF39BB 7DE7B05C A0F1ECAA 316221F8 98301D06
03551D0E 04160414 25CE9283 EF39BB7D E7B05CA0 F1ECAA31 6221F898 300D0609
2A864886 F70D0101 05050003 8181003B FCD8051E 2130E439 384158C8 7395A50E
D696B4BD 5B94C55C DCD20CC0 6EBA88D7 BC15645F 6C6E351F 17E56701 DE7673F0
81E08781 576F7203 B6D79B74 9D931C09 1E483811 B3C4F14D 56DBC165 B8BDDCE9
E3E7FDA7 501EB87F 5B41AC14 B1F53495 06A8185B 90449B7F 1FA47988 E2D377A9
58C1953B 9D18F4FA B2BA102C 7C390D
quit
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
class-map match-any non-client-nrt-class
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
interface Port-channel1
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
switchport nonegotiate
interface TenGigabitEthernet1/0/3
interface TenGigabitEthernet1/0/4
interface TenGigabitEthernet1/0/5
interface TenGigabitEthernet1/0/6
interface TenGigabitEthernet1/0/7
interface TenGigabitEthernet1/0/8
interface TenGigabitEthernet1/0/9
interface TenGigabitEthernet1/0/10
interface TenGigabitEthernet1/0/11
interface TenGigabitEthernet1/0/12
interface TenGigabitEthernet1/0/13
interface TenGigabitEthernet1/0/14
interface TenGigabitEthernet1/0/15
interface TenGigabitEthernet1/0/16
interface TenGigabitEthernet1/0/17
interface TenGigabitEthernet1/0/18
interface TenGigabitEthernet1/0/19
speed 1000
channel-group 1 mode active
interface TenGigabitEthernet1/0/20
interface TenGigabitEthernet1/0/21
interface TenGigabitEthernet1/0/22
interface TenGigabitEthernet1/0/23
interface TenGigabitEthernet1/0/24
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface TenGigabitEthernet1/1/5
interface TenGigabitEthernet1/1/6
interface TenGigabitEthernet1/1/7
interface TenGigabitEthernet1/1/8
interface FortyGigabitEthernet1/1/1
interface FortyGigabitEthernet1/1/2
interface Vlan1
no ip address
shutdown
interface Vlan11
ip address 10.67.0.254 255.255.255.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
snmp-server community hokfarida RO
line con 0
password 7 070E2F5F47584B5E50
login local
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 12180B041B5A5E5F6D
login local
line vty 5 15
login
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
hi,
i see show cdp nei it show the output mismatch while the connectivity is point to point there is no multipale path and also no hum nothing straight connection from core to switch
