Showing results forĀ
Search instead forĀ
Did you mean:Ā
problem in two switch communicate
hamedha
I try to create communicate between 2 different switch model 4500 and 3750
I can ping vlan in switch 3750 from host in swith 4500
but I cannot ping host in swith 4500 to host inn switch 3750
attached configuration
11 Replies 11
Francesco Molino
When you're trying to ping from hosts attached to 3750 to hosts attached to 4500, are these hosts in vlan 10?
If not, can you test just from host to host in vlan 10?
What is the default gateway of hosts in both switches?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
thank you for your fast repaly
host in switch 4500 in vlan30 default gateway 192.168.30.100
host in switch 3750 in vlan10 default gateway 10.40.10.150
from host in vlan30 i can ping 10.40.10.150 but i cannot ping host in vlan10
on 3750 switches no need to configure SVI, if you configured SVI for remote accessthan  update host gateway connected hosts on 3750  to  10.40.10.100 and don't forget to configure the "ip default-gateway 10.40.10.100 "
BR
Tayyab
*** Please rate all helpful responses and mark solutions***
From vlan 30, sure you can ping 3750 vlan 10 interface because your 4500 has an IP into vlan 10 and knows how to reach 10.40.10.150.
The invert isn't true because when hosts try to reach vlan 30 hosts, they arrive on your 3750 svi and this switch has no clue how to reach vlan 30. What you can do very easily is to add a static route on your 3750 to allow hosts to talk to each others.
The static route on 3750 switch should looks like:
ip route 192.168.30.0 255.255.255.0 10.40.10.100
Can you test and let us know please?
Francesco
I added as you told me
but I cannot ping
From the 3750 switch itself, can you ping 4500 IP 192.168.30.100 ?
Can you make sure ip routing is enabled on your 3750?
Can you share a diagram please?
Francesco
From the 3750 switch itself, can you ping 4500 IP 192.168.30.100 ? yes I can ping
Can you make sure ip routing is enabled on your 3750? yes its enable
PC1------------Switch 3750---------(interface trunk 1/0/8 )Switch 4500---PC1
 Switch 4500:
vlan10
ip address 10.40.10.150
vlan20
ip address 192.168.30.100
 vlan 30
ip address 192.168.1.100
Switch 3750:
vlan10
ip address 10.40.10.100
now at least I want users in Switch 3750 (vlan10) ping users in  Switch 4500 (any vlan).
Hello
3750
ip routing DISABLED
trunk to 4500 (allow all vlans)
l2 vlans are populated in bro database
4500
io routing ENABLED
trunk to 3750 (allow all vlans)
L2 vlans are populated in fro databae
host pc
disable any software Fw on pc just make sure icmo isn’t be restricted
has deafult gateway of L3 svi to which vlan it is assigned to
Kind Regards
Paul
will you please change the DG of your hosts in Vlan10 to 10.40.10.100, ie. int Vlan10 address at switch4500 instead of 10.40.10.150. If your trunk between both swithes is set up correctly this should get the required result.
Best regards,
Antonin
Please share the diagram and where is the host.
I could see an interface under VRF
interface FastEthernet1
ip vrf forwarding mgmtVrf
speed auto
duplex auto
Normally we cannot reach an IP inside interface from outside untill the interface under VRF is directly connected to other switch.
PC2-----------InterfaceVRF-Switch A---------Switch B---PC1
                                               PC3
In this case PC1 cannot ping PC2, however, PC1 can ping PC3.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
Leo Laohoo
Is the link between the two even up?
