Showing results forĀ
Search instead forĀ
Did you mean:Ā
i can ping to my switch But WebUI Doesn't load completely
ImanHg72
hey guys.
i had an 2811 router and 2960 switch. the router was doing intervlan routing  and was connected to main router.
i recently replaced them with C9200L L3 Switch.evrery thing is connected. but i have dlink switch on wich is connected through this switch to my main router on diffrent vlan. connecivity is ok and have ping.but when i try to access dlink switch webui the page doesn't load fully to manage it from  another subnet.on same ubnet its ok.
there isn't any firewall rule or access policy defined on main router  and 9200 switch.
i checked with wireshark  it seems after some packets recieved , other packets does not comming and tcp retransmit sended to switch unitl tcp reset packet sended by dlink switch.
only basic configs are running now for test . but problem is not solved.
0 Replies 0
