I can't connect to my remote SG550
pgreen
I can't connect across the network via SSH or HTTP.  I can ping the switch and it's passing traffic.  Where do I start?
Ruben Cocheno
@pgreen
Connect to the Console as per below, and check if the ssh/http(s) are enabled.
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-300-series-managed-switches/smb4984-access-the-cli-via-putty-using-a-console-connection-on-300-a.html
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
