I cannot ping an outside webserver - Packet tracer help
TotoCutugno
Hi There!
I am trying to build a network with a 3-tier firewall. For some reason, i cannot ping the web server outside my firewall from my inside desktop. I have follow all the instructions, i have tried to change the hardware - it does not work. I attach here my both packet tracer files. Probably someone can point at my mistake. I share the files on the google drive: https://drive.google.com/drive/folders/1KYcWK7tngdih63eJzCQU0FICy4zMWehx?usp=sharing
Thanks a lot!
the main problem is the (mis)confguration of the Internet router. Also, the IP address of the ASA outside interface is on a different subnet than that of the router. Make sure the configs look like below (important parts marked in bold). Also, the webserver had no default gateway configured.
Attached the revised file.
Router#sh run
Building configuration...
Current configuration : 668 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 8.8.8.1 255.0.0.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.10.11.10 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
no ip address
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.11.20
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
ciscoasa#sh run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
switchport access vlan 3
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 10.10.11.20 255.255.255.0
interface Vlan3
no forward interface Vlan1
nameif DMZ
security-level 70
ip address 192.168.2.1 255.255.255.0
object network INTERNET
subnet 192.168.1.0 255.255.255.0
nat (inside,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 10.10.11.10 1
access-list INTERNET extended permit tcp any any eq www
access-list INTERNET extended permit icmp any any
access-group INTERNET in interface outside
telnet timeout 5
ssh timeout 5
dhcpd dns 8.8.8.8
dhcpd auto_config outside
dhcpd address 192.168.1.3-192.168.1.17 inside
dhcpd enable inside
ciscoasa#
what instructions are you following ? The configurations look good, the problem is that especially on the ASA in Packet Tracer, a lot of things don't work as expected, or don't work at all.
Hi Georg,
Thank you for getting back to me. The instruction I am using is this:  https://www.youtube.com/watch?v=iNESd1I8E88&t=694s
Router#sh run
version 12.4
hostname Router
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
no ip address
clock rate 2000000
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
ciscoasa#sh run
: Saved
ASA Version 8.4(2)
hostname ciscoasa
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif DMZ
security-level 70
telnet timeout 5
ssh timeout 5
dhcpd dns 8.8.8.8
dhcpd enable inside
ciscoasa#
Omg, thank you so much! Very detailed and very well explained!
