I have 80% of cpu load
pacquaviva
I have a 7200 and I have changed the configuration from an interface f0/0.1 to interface f0/0 with the same configuration.
It happens that the load of cpu is increased up to 80% from 25%.
The ip cef is enabled.
I don't know why.
Regards.
Thank you.
Paolo
8 Replies 8
network.king
Level 4
Level 4
Hi Paola,
Can u pls provide the interface config and " sh proc cpu sorted " output to check further
regards
vanesh k
the configs are the following:
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address X.X.X.X 255.255.255.128
ip access-group 106 out
ip summary-address eigrp x92x X.X.X.0 255.255.224.0 1
ip policy route-map Ascete-from-out
end
interface fastethernet0/0
end
Could you give us the output of :
show ip interface fa0/0
(btw use: show proc cpu | e 0.00)
Vlad
I try to do the command show ip interface f0/0 e f0/0.1 and I noticed only a difference (
"IP fast switching on the same interface is enabled" in f0/0.1 and "disabled" in the f0/0) as you can see:
FastEthernet0/0.1 is up, line protocol is up
Internet address is x.x.x.x/25
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.10
Outgoing access list is 106
Inbound access list is not set
Proxy ARP is enabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP Flow switching is disabled
IP CEF switching is enabled
IP Feature Fast switching turbo vector
IP Feature CEF switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is enabled, using route map Ascete-from-out
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
IP multicast multilayer switching is disabled
7200-Acc#
7200-Acc#sh ip int f0/0
FastEthernet0/0 is up, line protocol is up
MTU is 1500 bytes
IP fast switching on the same interface is disabled
7200-Acc#
Nevertheless I put this command on interface f0/0 and the load of CPU remain the same (about 90%).
What can I do?
Paolo
It would also be nice to have a "show proc cpu sorted" and "show interface fa0/0 switching".
Hi take this output from show interface f0/0 switching when its configured the subinterface f0/0.1
7200-Acc#sh interface f0/0 switchin
FastEthernet0/0
Throttle count 4893
Drops RP 9726 SP 0
SPD Flushes Fast 9 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 2 Drops 0
Protocol Path Pkts In Chars In Pkts Out Chars Out
Other Process 4557 333003 66082 3964920
Cache misses 0
Fast 0 0 20847785 1387756410
Auton/SSE 0 0 0 0
IP Process 100042013 4020783004 39234921 4216032315
Cache misses 1209
Fast 3126385202 2641383635 3024436771 3724178050
Auton/SSE 0 0 0 0
DEC MOP Process 0 0 1108 85316
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
ARP Process 224516 14367724 47537 3040268
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
CDP Process 11010 2389170 11036 3640780
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
PPP over ATM Process 0 0 0 0
Cache misses 0
Fast 0 0 35215000 2358486648
Auton/SSE 0 0 0 0
7200-Acc#
Here the logs when it's configured the main interface with the route-cache same-interface:
7200-Acc#sh int f0/0 switching
FastEthernet0/0
Throttle count 5040
Drops RP 10025 SP 0
SPD Aggress Fast 0
Other Process 4570 333718 66122 3967320
Cache misses 0
Auton/SSE 0 0 0 0
IP Process 100382254 4267242121 39263557 4230007299
Cache misses 1209
Fast 3128251944 4061004637 3026496371 427678000
Auton/SSE 0 0 0 0
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
ARP Process 224689 14378788 47546 3040824
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
CDP Process 11016 2390472 11045 3643480
Cache misses 0
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Cache misses 0
Fast 0 0 35229027 2359413310
Auton/SSE 0 0 0 0
7200-Acc#
Paolo
Hi, I notice you are running policy routing. Do you have many hits on this feature? Have you tried to enable fast switching for policy routing?
"ip route-cache policy"
No, I'll try.
I let you know something.
Thanks.
Paolo
