i have a question about creating a vlans on layer 2 switch
dolanduck.
Im Confused with svi on a layer 2 switch.
How come on my layer 2 switch when i create vlan 99 and i give it a ip address of 10.0.0.2 and and 10.0.0.1 on a router interface my router cant ping my vlan 99. Is it because vlan 99 Its not assigned to a interface or no intervlan routing.
Help
7 Replies 7
Reza Sharifi
The port that connects the switch to the router needs to be in vlan 99 as well.
ok is that the reason it works with vlan 1 because by default all ports belong to vlan 1 ?
Yes, you are correct.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
There is a single rule that If you want to communicate with any device from the switch (Managemenable with VLANs) then there must match the VLAN assignment or Layer 3 interface configuration the same as a remote peer.
Suppose: .
Router (gig1/1)-----------(gig1/0/1)Switch
your router configuration is like:
interface gig 1/1
no shut
ip address 10.0.0.1 255.255.255.0
and your switch configuration must be like (If you want to use SVI):
vlan 99
interface vlan 99
ip address 10.0.0.2 255.255.255.0
interface gig 1/0/1
switchport mode access
switchport access vlan 99
Deepak Kumar
Deepak Kumar,
is it the same with a layer 3 switch if i enable ip routing.
Yes, the same with ip routing or without it. But if the switch is just layer-2, you don't need IP routing at all. All you need is a default-gateway statement.
thanks im now going to connect my layer 3 switch to my router then my layer 2 switch to it.
