Intervlan Routing With OSPF
Atheeleon
Community Member
Hello, everyone.
I have a college project where I need to make a intervlan communication between these 3 switches using OSPF. I have searched the internet for every possible solution, but I can't seem to find the answers.
Here's what has been done so far:
The main network is 172.100.0.0/24 and the sub-net has been divided into /27
I am using these subnets:
172.100.0.0/27
172.100.0.32/27
172.100.0.64/27
I have created 3 Vlans in each switch:
Vlan 10 (172.100.0.0/27)
vlan 10
name Andar1
int vlan10
ip add 172.100.0.30 255.255.255.224
no sh
Vlan 20 (172.100.0.32/27)
vlan 20
name Andar2
int vlan 20
ip add 172.100.0.62 255.255.255.224
no sh
Vlan 30 (172.100.0.64/27)
vlan 30
name Andar3
int vlan 30
ip add 172.100.0.94 255.255.255.224
no sh
Each switch has ALL of its Fa interfaces in Access Mode to one specific vlan.
SW1
int range f0/1-24
switchport mode access
switchport access vlan 10
no sh
SW2
int range f0/1-24
switchport access vlan 20
no sh
SW3
int range f0/1-24
switchport access vlan 30
no sh
Each switch has their Gig interface in Trunk Mode.
SW1
int range g0/1-2
switchport mode trunk
no sh
SW2
int range g0/1-2
no sh
SW2
int range g0/1-2
no sh
The network inside each switch is working perfectly. The problem is that I don't know how I can make this intervlan communication using OSPF routing.
How can I make this work?
Hell0
Looks like you are wanting to to extend your L3 connectivity down to the access layer and if you to do that then the vlans cannot be extended over to the other switches.
In the below example i have used three additional subnets for the l3 mgt connections.
Sw1-Sw2 MGT link 172.100.0.96/29
Sw1-Sw3 MGT link 172.100.0.128/29
Sw2-Sw3 MGT link 172.100.0.160/29
SW1
int x/x
description MGT link sw1-sw2
ip address 172.100.0.97 255.255.255.224
ip ospf network point-to-point
int x/x
description MGT link sw1-sw3
ip address 172.100.0.129 255.255.255.224
int vlan10
description server-PT
router ospf 1
auto-cost reference-bandwidth 1000
passive-interface default
no passive-interface default interface (sw1-s2)
no passive-interface default interface (sw1-s3)
network 172.100.0.30 0.0.0.0 area 0
network 172.100.0.97 0.0.0.0 area 23
network 172.100.0.129 0.0.0.0 area 23
area 23 stub no-summary
vlan 10
exit
SW2
int x/x
description MGT link vlan sw2-sw1
ip address 172.100.0.98 255.255.255.224
int x/x
description MGT link sw2-sw3
ip address 172.100.0.161 255.255.255.224
int vlan 20
description Andar2
no sh
router ospf 1
no passive-default interface (sw2-s1)
no passive-default interface (sw2-s3)
network 172.100.0.98 0.0.0.0 area 23
network 172.100.0.62 0.0.0.0 area 23
network 172.100.0.161 0.0.0.0 area 23
area 23 stub
vlan 20
exit
SW3
int x/x
description MGT link sw3-sw1
ip address 172.100.0.105 255.255.255.224
int x/x
description MGT link sw3-sw2
ip address 172.100.0.162 255.255.255.224
int vlan 30
description Andar3
no sh
router ospf 1
no passive-default interface (sw3-s1)
no passive-default interface (sw3-s2)
network 172.100.0.94 0.0.0.0 area 23
network 172.100.0.105 0.0.0.0 area 23
network 172.100.0.162 0.0.0.0 area 23
area 23 stub
vlan 30
exit
Kind Regards
Paul
Hey, thanks for the response.
Should I change my 2960 to 3560/3650? Or should I connect the L3 switches
to the L2's?
