I have a question.
석광원
Hi~
Chassis is composed of below module.
Chassis = C4510R
Slot1. WS-X4516
Slot2. WS-X4516
Slot3. WS-X4148-RJ-45
Slot4. WS-X4148-RJ-45
Slot5. WS-X4148-RJ-45
Slot6. WS-X4148-RJ-45
Slot7. WS-X4148-RJ-45
Slot8. WS-X4148-RJ-45
Slot9. WS-X4148-RJ-45
Slot10.WS-X4148-RJ-45
When above case run, status of slot10 is "Not Support".
Command is used "show module"
I am wondering why slot10 isnot support.
I think that because Backplan but I don't know well.
5 Replies 5
Giuseppe Larosa
Hello Kwangwon,
it can be a question of power budget.
What happens if you remove one of the linecards for example the one in slot 3 ?
Hope to help
Giuseppe
Hi~ Giuseppe
C4510R' capacity is 136Gbps and WS-X4516' swiching capacity is 96Gbps.
So isn't it possible ?
When I tested linecards it is good.
Hello Kwangwon,
I was meaning power consumption of modules not bandwidth or backplane issues
check with sh power
Hope to help
Giuseppe Larosa
agugger
The 4516 has 96 1Gig Channel to support the line cards. 6 Are used per slot. Both 4516 borrow theirs uplinks from these 96 Channels. So the slot 10 can a maximum of 2 gig use. So only the 4502 line card can be used in this situation.
The 4516-10GE is different it has 96 Channels for the line cards plus the 10gig uplinks. But you have decide between the 4 1gig ports on the 4516-10GE sup exclusive or the slot 10.
hth
Andy
agugger
Hello Kwangwon,
The following note can you find at the “Release Note for the Catalyst 4500 Series Switch” see the link below:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/release/note/OL_5184.html
Contains:
When you use Supervisor Engine V in a Catalyst 4510R or 4510R-E chassis, slot 10 (FlexSlot) only supports the following linecards: the two-port GBIC (WS-X4302-GB) and the Access Gateway Module (WS-X4604-GWY). Supervisor Engine V-10GE has this same restriction when you configure its uplink select mode to all. Supervisor Engine V-10GE supports all Catalyst 4500 Series linecards in slot 10 when its uplink select mode is configured as tengigabitethernet or gigabitethernet. Supervisor Engine 6-E supports all Catalyst 4500 series linecards in slot 10.
Andy
