i have cisco 881 router and configuration is
sathisha74
my problem is i can ping internet from router but not from pc can nay body help me
2 Accepted Solutions
johnd2310
Level 8
Level 8
Are you doing NAT? Have you checked your NAT configuration. Is there another device upstream of your router? Have you checked your routing?
post you configuration so we can review it. Remove any confidential info.
John
**Please rate posts you find helpful**
Hi, You will need to start with a simple configuration. Assuming your clients are on 10.10.10.0/24 network, your nat statement should be ip nat source list 10 pool net-208 and access-list 10 would be
access-list 10 permit 10.10.10.0 0.0.0.255
your access -list 10 in the original configuration was wrong.test this and see if it works
John
johnd2310
Level 8
Level 8
John
sathisha74
yes i am doing nat  please find attchment of my confn
John
