I have problem with protocol down, HSRP not working too
nadbal07
I have problem with "Router1".
When I run "show ip interface brief" its says the protocol is down but the status is up. I don't know whats the problem and what I did wrong, but maybe because of this I can't make HSRP between Router 3 and Router 1.
Please if someone could check the topology and troubleshooting would be helpful, because I need it for project.
the subinterfaces are configured on the wrong interface, GigabitEthernet0/1 instead of GigabitEthernet0/0.
GigabitEthernet0/1 is not active, there is nothing connected.
Make sure the configuration of Router1 looks like below. Attached the revised, working file.
Router#sh run
Building configuration...
Current configuration : 1429 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
no ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX1524USUP-
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.3 255.255.255.0
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 192.168.20.3 255.255.255.0
interface GigabitEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.3 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/0/0
no ip address
clock rate 2000000
shutdown
interface Serial0/0/1
ip address 200.100.20.1 255.255.255.252
clock rate 2000000
interface Serial0/1/0
no ip address
clock rate 2000000
interface Serial0/1/1
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
passive-interface GigabitEthernet0/0
network 200.100.20.0 0.0.0.3 area 0
network 192.168.10.0 0.0.0.255 area 0
network 192.168.20.0 0.0.0.255 area 0
network 192.168.30.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
Router#sh run
version 15.1
hostname Router
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
clock rate 2000000
shutdown
clock rate 2000000
no ip address
clock rate 2000000
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 1.1.1.1
ip classless
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
nadbal07
Oh my god!
Thank you for your help, I tried to find solution for days, and you helped me! Thank you again!
glad it is resolved !
